Question about Hotpoint HTS16HBR Top Freezer Refrigerator
HI, IT'S A HOTPOINT FRIDGE FREEZER 5 YEARS OLD AND RECENTLY STARTED MAKING NOISE THAT I CAN ONLY DESCRIBE AS AN AIR RAID SIREN. I AM USED TO THE NORMAL HUMMING NOISE.
  • 11,800 Answers
A part inside your fridge has got loose and it's vibrating. The only way to fix that is to take out the fridge and check every single part in or on it - tighten every bolt, check every pipe and make sure nothing moves abnormally.
Posted on Aug 24, 2010
  • Azrael SRL Aug 24, 2010
    Something just passed my mind - are you sure that what you hear isn't the door open alarm?  If it's that then check the door switch, it's busted.
Noisy and fridge not cold
well i rember that guy??? that was when i had hair!!!!!!!!!!! sadly its gone now? along with my "get up and go" that got up and went!!!
your fridge,,, come on now,,its 10 years old,, dont you think you have had your moneys worth out of it yet?,,it needs a re-gas, pricy job that is, also maybe a thermostat as well,,,do yourself a faver dont spend money on it, its well past it,,bit like me now! save your cash and get a nice new fridge,,,just so you can show it off to all your palls,,, the old Dr who???happy days "A"?
May 05, 2010 | Fisher and Paykel Active Smart E522B...
Our cleaner has recently started making a sound like an air raid siren. We have cleaned all filters no difference the noise is terrible.
Check the drive belts for wear and tightness and make sure that the front brush(es) are clean and free of all hair and fabric. This will normall cure the problem
Nov 14, 2009 | Bissell 3750 Lift Off Bagless Upright...
RLA Future Hotpoint Fridge
This may be caused by a fanmotor touching something, or one of the copper tubes from the compressor causing a resonant frequency. If you touch the different tubes to find out which one is causing the noise and then slightly bend it with your fingers. That should stop the noise.
Mar 13, 2009 | Hotpoint RLA30 Compact Refrigerator
Fridge making a humming noise every 3 min
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Help
Well mine went through some of the same thing the fridge put out less and less cold ait and the freezer started to thaw just a tad on max settings. Mines about 8 years old and a kenmore.
Made the decision on an opportune time when Sears was having an additional 10% off sale..... my problem will be fixed ina bout 2 hours when my new fridge is delivered. The sad truth is (I now its cliche) they don't make um like they used to. Last fridge i had lasted nearly 20 years. Now if you get more than 5 out of an appliance you're doing good. Good luck but it sounds like the compressor died. You'll either need an expert to come out (think they have a min fee of $100 or more) or repalce it.
Jun 17, 2008 | GE GSH25JFR Side by Side Refrigerator
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
43 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
