Question about Alpine NVDV002
NVD-VOO2 will not load chrash out when disc is half way through loading
Have the same problem and its been hapening since February. Thought that it was earthquake as I live in Lincs and son said it might be lazer but have finally rung aloine and they say its a satellite problem to do with US putting up more sats and the software can't read it. They are sending me out a free disc to sort it out but need to follow instructions implicitly. Hope this is solution to your problems Ring alpine number is 08703 333761
Posted on May 30, 2008
Hi my ps3 is not loading disc (it will load when machine is off and then you turn on with disc half inserted). When in will not play game.
this is a disk reader problem and u see the disk is spiinning after u insert it and if not u can clean and try it..then also u hav som problem then u can see this site to solve it..
Dec 12, 2010 | Sony Playstation 3 (PS3) Console
I have startup problem with my Toshiba A205-S4587 laptop. It shutdown after half loading or more than half loading Toshiba logo screen. No Beeps No led flash.
Have you tried tapping the F8 key when you boot up your laptop to get to the safe mode menu where you can then either select the last known good configuration or load safe mode. If this doesn't work try getting to a dos prompt and run chkdsk /f to check for hard drive errors. If all else fails you could reload the operating system from the original disc but you'll lose all of your files or you could try the recovery discs that came with the laptop but sometimes that results in the same thing. There are other options such as ultimatebootcd or taking the drive out and putting it into a USB HDD docking station to recover your files before formatting and reloading the o/s. Good luck.
Sep 30, 2010 | Toshiba Computers & Internet
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
Save issues bad company
your only option is to Restore PS3, and this is found under System Settings.
Then see if it works.
Oct 15, 2008 | EA - Electronic Arts Battlefield Bad...
Playing PS2 on apple iMac
if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
you could buy an external CD/DVD drive and then use smaller discs with the iMac.
Jun 10, 2008 | Apple iMac G5 Desktop
Nvd v002 alpine navigation
I have the same problem and its been hapening since February. Thought that it was earthquake as I live in Lincs and son said it might be lazer but have finally rung aloine and they say its a satellite problem to do with US putting up more sats and the software can't read it. They are sending me out a free disc to sort it out but need to follow instructions implicitly. Hope this is solution to your problems Ring alpine number is 08703 333761
Mar 06, 2008 | Alpine NVDV002
Says Bad Disk
I WENT BACK LATER, ROTATED THE DISC ABOUT HALF A TURN AND IT LOADED. TOOK IT OUT PUT ANOTHER IN AND IT LOADED JUST FINE ALSO. MAYBE IT WILL KEEP WORKING OK.
Oct 27, 2007 | GPX D1816 DVD Player
Jensen 9411 WILL NOT LOAD ANY DISC
It's a problem that a lot of people that have this unit is having, the solution is repair center and not to purchase this unit anymore it problem that Jensen audiovox need to use better parts
May 05, 2007 | Jensen VM9411 Car Video Player
Unit will not start or load disc
Try opening up unit and using canned air and blow it out - sometimes simple dirt causes things like this While inside glance and see if you don't have some old tape or bits of labels that have come off and are anywhere inside that might be hanging the various working areas. Try using cd cleaning disk and vhs cleaning tape Without seeing this not sure what is causing it but may be something simple like the dust or pieces of label causing problems or the little rubber "tires" and other rubber components having gotten stretched out and slipping.
Nov 05, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Car Audio & Video Logo
97 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
