Question about Poulan Pro Gas BlowerVacuum ()
Am replacing ignition module , What is the gap setting ? Poulan mode; BVM200VS
  • 183 Answers
Use a clean and dry business card or other card stock paper to set the gap. That is almost perfect for the .006" setting.
Posted on Aug 24, 2010
Poulan Pro blower BVM200vs won't start. No spark, changed coil, now I have spark, gas flow good. Tried grounding kill switch to engine & tried removing switch. Do magnets need 2 B indexed to shaft?
The flywheel should have a woodruff key on it, which fits in the groove on the crank shaft. This means the timing is pre set. When setting the timing gap, use a business card between the magnet on the flywheel and the ignition module, tighten them in that position and remove the card.
Is fuel getting into the cylinder and actually wetting the plug.?
Do you have good compression?
May 22, 2016 | Poulan Garden
How do you know if you are getting spark
check to see if it is sparking the plug
Jul 08, 2014 | Poulan Garden
I have a Poulan BVM200vs Leaf blower and can not get spark,I have changed the ing module and set the gap to 10 thousands
remove the wires that go to the kill switch and try it if still no spark the coil is bad
Jul 05, 2012 | Poulan Garden
Poulan pro bvm200vs, what is the spark plug gap suppossed to be set at?????????????
re: "The plug should be set from the factory check your manual for the gapicon1.png setting"
Chris, If people had the manual do you honestly think they would waste their time looking for the answer online.
Chris - I hope you don't get paid for offering 'Check your manual' answers.
Feb 19, 2011 | Poulan Pro Gas BlowerVacuum ()
Air gap setting
I assume you are speaking of the ignition module pole gap to the flywheel. Rotate the flywheel magnets under the ignition module poles, and use a thin business card for a gauge. With the card in place, loosen the module screws and allow it to contact the magnets, then re-tighten the screws. Rotate the flywheel to remove the card, then turn the flywheel one full turn to make sure the gap does not close up at any point. Don't forget the ignition switch wire. Hope this helps!
Jul 06, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan BVM200VS gas blower. The plug won't fire. It has a new spark plug and a new ignition module. The kill switch is good. What little wiring there is seems to be good. If you spin the flywheel...
It is possible that the gap between the module and the flywheel is not correct. This gap is usually set with some thin card stock or possibly a playing card.
It is important that this gap is not too large.
Apr 16, 2009 | Poulan Garden
Poulan Pro Gas BlowerVacuum () Logo
752 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
