Question about Panasonic Microwave Ovens
I have bay a national micowave modle no NNV691JF in year 2004-05. Now it is not working (its push push button on pannel not working ) . So kindly sent the address the repair shop at patiala in punjab thankyou. Jasvir Singh 9815617880
Our 1.5 year old whirlpool micowave keep sending a message open close door check time microwave will not work till several tries later.
The door sensing switch is faulty. You have to replace the switch.
If you wish to get some details about Microwave oven repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Whirlpool Microwave Ovens
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
Jan 18, 2010 | Samsung Microwave Ovens
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
SHARP MICOWAVE,PUSH RELEASE BUTTON AND SHORTS ELECTRIC OUT?
There's a problem with a door switch or door switch mount.
All three switches should be replaced in this case.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We might even have the service manual if you can reply back with your full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 27, 2008 | Microwave Ovens
My Touch pad does not work, can someone help? kenmore mocrowave model 721.62624200 microwave buttons work sporatically. if i push in a downward motion they work sometimes microwave blew a fuse a couple of...
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Microwave Ovens
Help
Try to unplug the micowave and let it stay unplugged for 10 -15 minutes. Plug it back in after 10-15 mins and see if it resets the error message.
Jan 25, 2008 | Microwave Ovens
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
