Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Accidentally left freezer door ajar when we left for the weekend. Emptied all contents. Freezer seems to be OK, but refrigerator compartment is not getting cold. Ideas?
  • 4,793 Answers
Until the "fabric" of the freezer reaches -18c the fridge will seem to be not working.leave it to settle for 24hours.....keep the doors shut.
Posted on Aug 24, 2010
Why wont my refrigerator & freezer get cold?
If all is running, the compressor is not pumping properly, or the refrigerant is low. or blocked.
Apr 26, 2014 | LG Bottom Freezer Refrigerator w/ Swing...
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Beko
Then off for 24hours to defrost and then restart.
May 12, 2013 | Refrigerators
We left for the weekend and our freezer door was left ajar. Upon returning, we reset the temp., but the freezer never got below 17 and then it shut off again. Is it a complete loss?
It is possible that an excessive amount of moisture was introduced into the freezer compartment while the door was ajar. If there is excess frosting on the walls or around the door seal, defrost the unit and see if it cools better.
Jan 20, 2013 | Refrigerators
Freezer problem
Thank you for your interest. I had to call a technician who fixed the problem.
Jul 21, 2008 | Refrigerators
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
71 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
