Question about HP DesignJet 1050c InkJet Printer
I installed a new ink tube system on the hp 1050c and cannot get the tubes primed with the setup printheads
  • 17 Answers
SOURCE: HP DesignJet 500PS mixed ink color in tubing
Hi
Think this should be fairly easy. If it's still printing quite happily but just th colours are off, probably means your print heads are fine. Hold onto the new ones and return to store for credit.
All you cand do to flush out the system is to keep printing. Belt out a couple of phots and it should start to come good maybe 1-2 photos maybe 5-6. But should come good.
Regards
P.S.: refer to manual that you do now have all the rite tanks in the rite place.
Posted on Dec 29, 2008
SOURCE: w7200 plotter - the ink tubes are empty
download driver printer canon mp 150
Posted on Jan 20, 2009
  • 214 Answers
SOURCE: HP C6180 All-in-One Photosmart DK Cyan Blue ink
Try putting a solid cyan sheet on copy board and copy many times then try head clean You may need to repeat this several times
Posted on Apr 23, 2009
don_farr
  • 1018 Answers
SOURCE: HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Posted on Feb 24, 2010
mishrajk21
  • 202 Answers
SOURCE: I was settting up a
Try the following:
?? Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
?? Try purging the Ink Supply Tubes again once the Printer has been
rebooted.
?? Install new Ink Cartridges in to the Printer and try purging the Printer
again
If problem persists then replace the ink supply station(iss) assembly
Posted on Jul 17, 2010
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
I have a Designjet 5500ps Printer and it is leaking blue ink, when printing, all my research indicates that I need to replace the carriage tube connector, but I am unable to find the replacement part.
Hi there
May be you can try to contact any Authorised HP Service centre for your probelm. Could you give me your correct location so i can tell you whome to contact?
Alternatively you can try to see where the leakage is taking place and try to seal it with silicon sealent so it can atleast last untill someone attends to the probelm from HP.
The technical term for it is INK TUBE ASSY. But make sure and tell the HP people about the size of the plotter that is 42" or 60" and also keep the Product Number and Sl. No. of the machine handy which is required by HP technical team. (You can find it at the back of the plotter)
Click here to find all the spares for your plotter.
Aug 24, 2011 | HP DesignJet 5500PS InkJet Printer
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
My Designjet 4000ps is asking to install setup printheads
setup printhead used for priming of ink tube *** to remove the air from tube or blokage it comes with unit when u purchage, pls install them one for each colour then machine performs the test & then u install the new printhead & calibrate the plotor
PLS DONT USE THE OLD PRINT HEADS AFTER PRIMING>>>>>>>>>>>>>>>To keep the device safe
Apr 07, 2010 | HP Designjet 4000ps InkJet Printer
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Switch power off check printhead path(2)
Could be worn ink tube system and printhead cable snagging when the carriage moves, or dirty carriage support bar
Oct 12, 2009 | HP DesignJet 1050c InkJet Printer
Print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Sep 23, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
