Question about Garden
I need the manual for a Campbell Hausfeld Welder Model DK 6891 115 V Flux Core Welder 30-85 AMP output that I just bought
  • 8 Answers
SOURCE: convert flux to mig
need to buy a gauge set up , these usually come with the hose and gauge,just attach in the back and hook up your bottle..
Posted on Aug 12, 2009
  • 23 Answers
SOURCE: Campbell Hausfield wire welder feeds after trigger release!
has it done this before some wire feed welders the cheaper ones have hot switches mean that push wire all the time stuped i know but if it is not a hot switch than it is making contact some how and it could be inside the wip check it as best you can or take the wip in to where you got it from
Posted on Nov 10, 2009
skookumfab
  • 93 Answers
SOURCE: I recently inherited a Campbell
http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Posted on Dec 08, 2010
heatman101
  • 43501 Answers
SOURCE: I have a campbell hausfeld
The "DK" number you found is just a decal number...no help...
Does your sprayer look something like this???
http://www.paintpro.net/Articles/PP603/PP603_ProductNews-Campbell.cfm
You may be able to go to the Campbell Hausfield website and match something uo through pictures or even on the site that I gave you here...
Once you can narrow down the model number, you can get any of the manuals here...
http://www.chpower.com/webapp/wcs/stores/servlet/chService_10051_10001_-1
heatman101
Posted on May 09, 2011
heatman101
  • 43501 Answers
SOURCE: i have a campbell hausfeld
If you look around on the bottom of the compressor you will find a pipe plug at or near the bottom of the compressor.... that will be your drain for the oil... I often try to install a pipe nipple into the hole after removeing the plug so that the oil will run out far enough to be able to catch it easily...
The plug amy also be a flush plug that will need to be removed with an Allen wrench.
Make sure that all air pressure is removed and that the electrical disconnect is shut down and locked out before draining the oil....
If you do insatll a pipe niple then also buy a pipe cap to cap off the nipple, so you do not have to install it everytime and make a mess...I have even installed a small ball valve on compressors that need the oil changed frequently, to make it even easier.
You basically cannot got wrong here...the plug that drains the oil will be the only hole at the bottom of the compressor.
heatman101
Posted on Jun 24, 2011
How to get it to turn on
Is it plugged into a hot outlet? Check it, that is the most likely problem!! Troubleshoot per the owners manual.
Sep 13, 2015 | Campbell Hausfeld WF2150 - Flux Core Wire...
Why does it cut out?
It probably has reached itsduty cycleevery welder has a duty cycle, it's usually a percent of that it can run continuously
Jul 15, 2014 | Campbell Hausfeld MIG / Flux Core Wire...
I need the gun for my 80 fluxcore mig welder
Hi:
Her's the link to the site; all you need to do is to input the model number.
http://www.chpower.com/manualsearch/
Sep 28, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
The gun on my welder is broken and need to fine a new one the wire feedes thru gun to weld it is a cambell hausfeld mig welder
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
Mar 02, 2010 | Campbell Hausfeld MIG / Flux Core Wire...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Convert flux to mig
Mar 16, 2009 | Welding Tools
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
