Question about Roper 24 in. RUD4000M Built-in Dishwasher
My dishwasher won't fill with water...
So I tried the float like I saw you tell another person, mine is fine so i'm stuck wondering what's next. It seems like it goes through the rest of the motions but when it's fill time it makes a kinda rrrrrrrrrrrrrrrrrrr sound. I looked inside where I could but I don't see any obvious obstructions...Any help is appreciated!!
  • yvonne113 Jan 14, 2009
    My dishwasher won't fill with water. I turn it on for a while and when I open the door it makes a rasping noise.
  • Anonymous Apr 07, 2009
    my dishwasher wont fill wilth water just makes a buzzing noise the bottom its full of water how do i drain it?
  • 290 Answers
The buzzing sound when it tries to fill is probably the water valve. You either have a problem in the plumbing so no water is getting to the machine, trash or rust clogging the water valve inlet, or the water valve has failed and needs to be replaced.
Remove the kick plate at the bottom of the machine and you will see your water valve, it will have the water supply line hooked to it.
Post back with the complete model number from the dishwasher if you need more help. Work is very busy right now and I am not able to be online very much but I will reply as soon as I can.
Thanks, Mike
Posted on May 07, 2008
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwasher not filling up with water
Hi
Daniel
Aug 15, 2011 | Viking 24 in. Professional Series VUD040...
Water is not filling up.
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher is not working will not fill with water
Hi
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
Dishwasher wont let water come in
Hi
Daniel
Jun 19, 2011 | Dishwashers
Dishwashers Logo
1,865 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
