Question about Dell Latitude C610 Notebook
Battery will not charge
The other day I noticed the battery stopped charging. I put in a new battery. I was using the PC with out the cord it did use some battery power, I pluged it in to charge the battery but it will not charge.... Help
Jeff
I have a very similar problem. My laptop no longer recharges its battery (type C1295). I checked by replacing the battery but with no success. The laptop light sometimes indicates it is charging up the battery but not actually doing so.
  • 1,512 Answers
Hi cdravi
Laptops have a power supply control section attached to, or part of the main board. This allows the laptop to switch charging on and off, and control power supply function to different areas of the machine. Sounds like you have a fault in this part of the computer. Off to Dell Service for that one I am afraid.
robotek
Posted on May 05, 2008
My laptop dell latitude2110 when it on it off imediately because I was charging it over nigth
If it's not plugged in after charging it and it shuts off could be a bad battery. Do a hard reboot by unplugging laptop, take out battery and hold down power button for 30 seconds. Once done put battery back in, plug in laptop, let charge and try using again with just battery after charging it for a bit.
If you notice after charging the battery overnight and you have the laptop on long enough to see if the battery is not charging it could be a bad charger cord, in which you will need to replace it.
Mar 16, 2016 | Dell Computers & Internet
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
My Acer Aspire one dosent charge completely to 100%, it stops at 87%. I have tried letting the battery run down completely, then starting a new charging process. formally it charges to 100%, then 3 days...
Hello.
From your description, your battery is losing its charge and needs to be replaced.
I'm experiencing charging problems with my own system and I noticed that the A/C adapter is very slightly frayed. So, check your A/C adapter as well and be certain that it is charging when you leave your system charging overnight. If you are still experiencing a problem, replace your battery.
Hope this helps.
Apr 02, 2011 | Acer Aspire One PC Notebook
Battery icon showing 0% available (plugged in, charging). I did not use laptop for roughly 3-4 weeks. I also did not notice any quick battery loss prior to this when not plugged in.
Hi
I would be tempted to leave laptop switched off and turn power plug on to charge up the battery before i use it for a couple of hrs at least and hopefully this will put some charge into the battery
they say that if you continously use the laptop with the power cord plugged in then you could
remove the battery completly to extend the battery life and just use the cord
that way the battery will last many years longer
Mar 06, 2011 | ASUS UX50VRMSX05 Notebook
Trying to charge, it shows hourglass then says dissabling hand held because of low battery and shuts off, then it does it all over again
take out your battery and put it back in then try charging it again. if it doesnt work try another outlet. This means your phoen needs to be charged and either your battery needs replacing or your charger. let me know what happens. should charge it for a couple hours at least
Sep 01, 2009 | RIM BlackBerry Pearl 8100
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
I purchased a Genuine Dell Battery, It arrived dead with 1 test light on battery itself at 0% charged, It only lasted 2 mins before the laptop died running on battery, It doesn't charge the Dell battery at all The replacement battery only shows a 1% charge every 7 hours or so, nor do I have a yellow, green, orange light, The only time I get a light on the battery led is if i'm running on batteries and the battery level is below 10%, Its orange for low battery.
Thanks in advance to anyone who could help me.
Oct 31, 2007 | Dell Latitude C640 Notebook
Dell Latitude C610 Notebook Logo
283 people viewed this question
Alun Cox
