Question about Apple iPod nano
Backlight Hi, can someone please help me - how do i turn off the backlight to save batteries. or is there a default setting to have it turn off after 30 seconds or a minute etc? (Ipod nano 4gb mp3 mp4) Thanks Em
    Novelist:
  • 173 Answers
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
Posted on May 05, 2008
My HCL LAPTOP Serial No:         8074AX076106 Laptop Name:  P21PDC After restarting this laptop it's date and time become default and I had a bios password which I had forgotten please help me to recover...
hi if you have a member of your family or if you know what you are doing then go for it. "* PLEASE TURN OFF AND UNPLUG ALL POWER SOURCES (Battery and Power outlet) *" remove the back cover of your laptop and remove every screw to get to the BIOS/ CMOS Battery. Simply remove BIOS/ CMOS battery on mother board. first on the bottom of the laptop there is a large cover plastic thing. unscrew that and a small circle battery will be there, take out battery. secondly: plug in battery or mains then, go on to the bios and add a password. last: once added, save exit then go back on bios page , insert the CPU battery and then save and exit turn off laptop wait 30 seconds switch back on go on bios and it should be done.u may need to insert date and timeXD ( PLEASE NOT THIS IN NOT 100% effective some laptops BIOS chip need to be replaced)
Hope this helped. Thanks
Apr 03, 2014 | Computers & Internet
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | RIM BlackBerry Pearl 8100
Cannot connect to internet using this~help!
Hi Friend,
Please follow the steps in order to resolve the issue;
I hope you have a cable internet connection.
1.Make sure the connections are properly fitted as mention below:
The wire coming out from the modem should be fitted into the WAN/INTERNET port of the router. Connect the computer to either of the four LAN ports.
2.At the back of the router there is RESET button, push and hold that button for 30 seconds and then release it.
3.Turn off the router for 30 seconds and turn it on after that time.
4.Type 192.168.1.1 in the address bar of the web browser (Internet Explorer, Mozilla) and hit enter
5.Enter the Username and Password(default password is admin and leave the username blank)
6.Under the setup page make sure "Obtain an IP Automatically" is selected and DHCP server is enabled. click save settings
7.Now Click MAC Address Clone
8.Enable MAC Clone Service and click the TAB Clone
9.Click save settings and turn off the router for 30 seconds and Turn it on after 30 seconds.
I hope this will resolve the issue.
Regards
Chiranjeet
May 28, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
THE CAMERA GOES DEAD VERY SOON WHEN IT TURNS ON. IT HAS GOOD BATTERIES.
Hi, I've scoured the 3 page manual and come up with this.:-
There is nothing wrong with your camera. The camera has a built-in power saving
feature that turns the camera off after 30 seconds of inactivity (default setting) to
conserve battery power. The auto off time setting can be changed in the set up menu.
Changing the Auto Off Time Setting:
1. Set the camera to Camera Mode.
2. Press the Menu button to display the main menu.
3. Press until the Setup is highlighted.
4. Press to enter the Setup submenu.
5. In the Setup menu, press to highlight “Auto Off Time”.
6. Press to enter “Auto Off Time”. Press to highlight the time you want.
7. Press the OK button to save your selection.
Hope this helps
Mar 05, 2010 | Concord Camera Eye-Q 4060AF Digital Camera
HELPP
i have exactly the same problem hpw do i sort this?? also i do not know the default passcode for the handset can someone help me as i dont havr the manual to look at ?
Jul 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Intel D865GLC Mother Board which wont save changes to BIOS
Hi Hans
Try to restore the bios to factory defaults.
then restart the Computer and then change your settings again and see if it works then
Apr 26, 2009 | Intel D865GLC Motherboard
M2N-SLI Motherboard issue.
Hi
If your computer was ok before you changed parameters in Bios then it is Bios fault:
Re inter Bios and Try to reset it to default.
If you can not get into Bios anymore  the problem is serious:
You must reflash Bios or reset Cmos ,and it could be vga or may be the wifi if you have one onboard.
see if you have a hardware store nearby and let someone fix it
if you .
It seems to be a common problem on all Asus Motherboards:
bios,vga,post etc...
Dec 12, 2008 | ASUS AI Lifestylestyle M2N-SLI Deluxe...
Setup problem
The admin user name and blank password, is a default setting of the dlink, perhaps somebody would have changed the default setting on it, Hence Please press the reset button and reset the device to factory defaults, you may need to press the reset button for 30 secs and once the reset is done, Unplug the power for 120 secs and then turn it back on. And now you can try the same, I strongly feel that it should work now, Furthermore the settings saved on the router would be set to factory defaults hence, you may need to configure the router/Modem for internet connectivity.
Kindly let me know the Kind of internet service that you are using for 'Help with modem/router configuration'
Happy Troubleshooting!!
Mar 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Garmin M5
Could it possibly be your backlight setting? I had a problem with my screen staying dark until i set the brightness level.
settings -> system -> backlight -> brightness -. then adjust your settings.
Aug 06, 2007 | Garmin iQue M5 GPS Receiver
Apple iPod nano Logo
296 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
