Question about Bosch Axxis WFL 2060 Front Load Washer
Leaks during wash cycle, rubber liner ripped, can we fix or do we need a technician?
  • 11,896 Answers
Yes you can do it yourself. This is how:
Taking the old gasket off is pretty easy. Putting the new one on is the tricky part.
When you take the old one off notice that it is attached in two locations. The inside of the washer opening and the washer drum. Take the washer opening wire off first. I used a needle nose pilers. You can see a spring near the door hinge on the outside of the washer. Once that is off you can put the gasket toward you. There is another spring that holds the gasket to the washer. That will just come out with the old gasket. Keep both the wire and spring fasteners. You will need them to put the new one on. The gasket will probably slimmy so have a place to put it down once its out of the washer.
Here is the part that you need to have alot of patients. Don't set a time limit to do this job.
I should tell you I'm not a professional repair man but here is how I got the gasket back in.
Clean out the gunk and slime from the inside of the washer. The drum will swing freely so you can get a rag or papertowel in between the drum and the washer. Work in reverse from how you got the gasket out. First put the new gasket in with the drain holes at he bottom of the door. The same principles apply as changing a bike tire. Keep streching the gasket around the drum until that part is seated. Don't worry about the door gasket yet. Take the spring fastener and tie a peace of cotton string to one end of it. Then wrap the string around the door hing to hold one end of the spring in place. You will have to work without seeing what you are doing for the next part. Pull the spring around the gasket as close to the drum as you can get. The spring will have alot of tension and will collapse the gasket a little. Then the spring up to the groove in the drum with the gasket seated in the groove start seating the spring in the groove. I used chop sticks and masking tape just like a bike tire wrench. I wedged the chop stick under the spring to hold that part in place then taped the chop stick to the door opening with the masking tape. Keeped working around the gasket until the spring was completely seated. Be carefull not to move the bottom of the gasket too much. You want to keep the drain holes at the bottom of the drum. Once the spring is seated around the gasket on the inside cut the string off the spring.
That is the hard part. After that attaching the outer part of the gasket to the door opening is pretty easy and the wire fastener when on with just using the needle nose piler to help pull it around the gasket.
Posted on Aug 24, 2010
Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
Rip in the rubber seal on my Kenmore Elite Quite Pak4 HE3plus..
you can get new seal at  www.repairclinic.com Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
May 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have Frigidaire front loading. During the spin
During fill only
All the time
Apr 03, 2009 | Frigidaire Washing Machines
Water comes out of soap dispenser
http://www.applianceaid.com/neptune.html click this link and click the required option in the link Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
Jan 27, 2009 | Maytag MAH6700A Neptune High Efficiency...
Siemens Siwamat 2105 washing machine leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Water leaking from bottom of front lode washing machine
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Frigidaire Gallery Washer GLWS1233 leaks water when after the wash cycle
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician fo Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    r further details.
Oct 11, 2008 | Frigidaire Washing Machines
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Bosch Axxis WFL 2060 Front Load Washer Logo
100 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
