Question about Microwave Ovens
I am looking for nstruction manal for Eleday daily twin hand blender. Thanks.
Does anyone know where i can download the nstruction manual for a NEC microwave Model No:N668E
I would try the NEC web site. You may want to double check the model number first.
May 16, 2016 | Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
IAM LOOKING FOR OPERATING MANAL
Check in this links:
- usersmanualguide.com/sharp/microwave (select your right brand)
- manuals/device/microwave_oven
Hope this helps (remember to rate this answer).
Jun 16, 2011 | Microwave Ovens
I need an owners manual for the Mega Pro Blender: HPB270N Where can I get one?
It looks like your blender is actually made by Waring. The best option is to go to their website and request a manual from them directly.
Jun 08, 2011 | Microwave Ovens
I need a gasket for my sunbeam blender/coffee mill model 2774 .
Hi and welcome to FixYa, I am Kelly:
Here are the parts that are available for your unit:
http://www.ereplacementparts.com/sunbeam-2774-blender-parts-c-116440_116442_116457.html?osCsid=rr7g7e3p7s5jfnk4rmdsk8cve2
I am assuming you need the gasket that is part of item 2 and comes with the blade assembly.
Note that it is back ordered and not available until 3/23/2011.
The part number is: 123250-000-000 Do a net search using the part number (images) and you will find other sources.
Thanks for choosing FixYa,
Kelly
Mar 12, 2011 | Microwave Ovens
My waring blender quit working. There was no burnt smell, just quit running. Is it repeirable?
Hi Cindy -
Technically, everything is repairable. The real question is: How much are you willing to spend on repairing an old blender? You should bring it to an appliance repair shop for an estimate, because without actually seeing it - it is going to be anybody's guess as to what is wrong with it based on the info you've provided (it is often difficult to diagnose this stuff by description only as most times methodical testing is required) . It may be a simple, inexpensive fix - or it may "break the bank."
While waiting for your estimate, you should price a new blender. You may find there are some that have more features for less than you paid for the Waring model (or even less than the repair estimate). Once you have the price for repair and the price for a replacement, you can decide which path is best for you.
I hope this help & good luck. Please rate my reply - thanks!
Jan 27, 2011 | Microwave Ovens
I have a Waring Blender 51BL25 that just stopped working. Can it or should it be repaired?
Hello Patricia. We are clearly living in an age of replace rather than repair. The reason is simple. Repair shops generally will not look at a small appliance for less than fifty dollars. Putting that much money into a repair than may be short lived doesn't make sense when a replacement blender is often less than fifty dollars on sale. Joe
Thanks for choosing Fixya!
Nov 23, 2010 | Microwave Ovens
Microwave Ovens Logo
141 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
