Question about HP Mini 1000 Netbook
Screen looks like a negative image very hard to read anything
SOLVED!!!
I have fixed my issue!!!!
Open the the monitor using a screw driver, (no screw closed in pressure) take out the from plastic, remove the 6 dark screw in order to disassemble the lcd from the back cover (pay attention to the camera cable)
In the back of the the LCD unit there is the inverter unit embedded on top of the LCD unit, there it written (DON'T TOUCH) it is covered by a transparent plastic. On this transparent plastic there is a smal squared recut that can be pulled up. having the PC turned on turn this screw until the the image come back to the normal color.
I have tested it and it worked fine on my netbook, I will not be responsable for any damage caused to your PC. Do it under your responsibility, I did it and it worked fine.
In my case the laptop was left on the BUS and it got a lot of vibration, I guess that was the reason why that screw lost its original position
Thanks
Cheers
Fabio
Posted on Aug 28, 2012
I have a new 3gs phone and have two questions. Does the bluetooth detect other devices to enable file transfer? My phone doesnt detect anything and the salesman said its for blue tooth headset only is this...
Bluetooth
iphone doesnt detect other devices iPhone has no A2DP Bluetooth profile, and it has been a real surprise. It only offers HSP/HFP Bluetooth profile (Headset Profile/Handsfree Profile) for mono headsets, which is not enough – you can use it only for phone conversations. A2DP's first distinguisher is Stereo of high quality for music listening. White on BlackWhite on Black is used to invert the colors on the iPhone display, which may make it easier to read the screen. The screen looks like a photographic negative when White on Black is turned on.
GPS
Yes, with A-GPS support
May 31, 2010 | Apple iPhone 3G
My Compaq CQ50-110 will not boot-up. The lights turn on, but the screen remains black and none of the start-up sounds begin. I have removed the hard drive and it works, power adapter is good, RAM was...
Look at the screen at a shallow angle and look for any 'ghosts;' images that you might expect to see during boot or after.
If you can discern anything, then it could be a failed back-light (fluorescent) or the inverter for it which is customarily on a single small board that is obviously connected to the display/cover half. This is potentially user replaceable with care and a few small tools.
Jan 12, 2010 | HP Compaq Presario CQ50-110US Laptop
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
Toshiba Satellite a-100 can`t power up
The RAM could be faulty.
Try and get the RAM tested in another laptop or at your friendly computer store.
Also can you hear the hard disk spinning.
Maybe it is booting up but you can't see anything on the screen, there might be a slight image on the screen, look at it at an acute angle.
Connect an external monitor to the laptop, power up the monitor and then the laptop, if you see a normal image the the problem is the backlight on the LCD screen.
Get back to me if this is the case.
Apr 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
My top screen looks like a tv that has static looks wavy and bars
well more than likely you closed it to hard. you will have to call a nintendo ds repair man. sorry. your reading from someone that had the same experience. i had to ship it to get a new top screen. sorry bout that.
Mar 31, 2009 | Nintendo DS Lite Console
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Scanning of negatives and slides to a computer -Is it possible
Please follow the instructions below to use the Scan and Save option in Smart Panel
1. Open Smart Panel and double-click Scan and Save
2. The scanner normally defaults to AUTOMATIC MODE and will scan without any intervention. Should you wish to use PROFESSIONAL MODE or HOME MODE, simply click on PAUSE and the MODE you wish to use.
3. After the scan completes, you will be taken to the VIEW IMAGES screen. Should you wish to change the file name, click on IMAGEXXXX( X representing the number) and enter the file name of your choice. Click NEXT
4. In the SAVE FILE screen, select your FILE PATH and FILE TYPE. After making the adjustments you wish, click on SAVE.
Nov 28, 2008 | Epson Stylus RX500 All-In-One InkJet...
Screen Image too light to read
Try tapping the power key while the unit is on.  This may activate a control for contrast and brightness.  Otherwise it's in the settings screen.  Try looking at the screen in bright sunlight it may be make the screen visible enought to see the settings.
Oct 14, 2007 | Garmin StreetPilot c550 GPS Receiver
Motorola V3 display
I just experienced this today. Phone was fine last night, pulled it out of my pocket this AM to find the colors like a negative, and text characters in reverse. I googled this "motorola reverse image" and only a couple of posts like yours exist. I powercycled it and it came back up OK... --Ken
Sep 12, 2006 | Motorola Mobility V300
HP Mini 1000 Netbook Logo
450 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
