Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic 47" projection tv, words on left of screen show in 3 different colors(3 separate words), right side has a blue band from top to bottom. went to convergence mode and adjusted all i can, fixed it a little. now the middle of screen is clear, but the sides are still a mess. this thing done or what
  • 1,476 Answers
Martymill2,
You need new convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get the parts and how to repair the unit.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Aug 24, 2010
47wx49e
Tell me if this is what you see: set comes on and after a few minutes (it has sound) you see a odd colored band of noise very dark and top to bottom to the right of center on the screen?
Apr 09, 2012 | Panasonic PT-47WX49 47" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Words on bottom of screen are showing 3 times and are curved with green and purple colors
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.These parts must change to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is...
needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Jan 08, 2009 | Samsung HL-R4667W Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Blue is just not right
Typical convergence problem. Your going to have to have the two convergence IC's replaced at one time but if you have no soldering skills or know about the safety facts with solid state TV repair, you really should call out a trained service person to assist this repair for you.
Oct 07, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
