Question about Epson Office Equipment & Supplies
I have an Epson Stylus DX4400. The paper will not feed. The feeder wheel go round but the paper does not feed
SOURCE: epson stylus DX4400 software wont
i have installed disc for printer but cant get it to print can you help please
Posted on Nov 06, 2008
SOURCE: lost disc to install epson
lost disc to install epson stylus dx4400 dont know how to istall without it?
Posted on Nov 16, 2008
tigertail
  • 163 Answers
SOURCE: How to scan on an Epson Stylus DX4400
To scan an image into your PC you need to use a piece of software called the Epson Scan Utility. This
comes on the installation CD with the printer but if you don't have the CD it can be downloaded from
Epson Support. For Europe:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84YT0DcLI1RrpNUFXBv2
99cYU003D
Or US:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Once it is installed it will put an icon on the desktop, or (if you have Windows) a folder in the Start
menu. Turn the printer on and start the Epson Scan utility (it doesn't work if the printer is off), it
can be used in 3 modes: Fully Auto, Home Use or proffessional. Fully auto is the simplest, just click
on the scan button. For the others be brave and experiment!
Please take a moment to rate this solution, thanks.
Posted on Apr 09, 2009
  • 13433 Answers
SOURCE: LOST INSTALLATION DISC DX4400
you can download the drivers from (does the same job as the install disc)
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cxyWBIk5wgudYaE4js5ge5JjWTi46Y6YREU003D&tc=6
Posted on Jun 18, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I have a new Epson Stylus SX115 and I find it impossible to load paper into it
To remove your problem follow the simple tecnique.
1. Open paper feeder.
2. In the paper feeder you will see a white feed roller gide.
3. Remove the roll gide from paper feeder.
4. In the center of the roll gide you may see a spring inside it. Remove it and set all the parts of the printer again. I think you will be relive from your problem.
Thank you.
Sep 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Printer won't print with Hahnemuhle 300gsm papers.
    Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
    Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
    Paper Feed problem
    Paper feeder problem. Replace it. Or just replace pick up rubber at paper feeder mechanic
    Jun 03, 2009 | Epson Stylus Photo R200 InkJet Printer
    Epson stylus c68 paper jam
    Hi Guest.
    Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
    Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
    Paper twists when feeding
    there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
    Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
    I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
    Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
    Epson Photo RX600 error messages
    Hi.
    Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
    Goodluck... Fixya me...
    Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
    259 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
