Question about Linksys Computers & Internet
How to change subnet mask in linksys modemam300
    Sergeant:
  • 486 Answers
You can either change it from your network connection properties or either can access your modem`s web bassed setup to change it from there.
Posted on Nov 06, 2013
How do you get your IP Address, Subnet Mask, and your Gateway codes
Connect your computer wired or wirelessly to your router.
in windows based comp
open command prompt
type -- ipcofig
you will get your answer
Jun 10, 2014 | Linksys -Cisco Wireless-G VPN Broadband...
Web based utility for linksys WGA54G wont open
My guess would be that the game adapter does not provide dhcp service.
Knowing that its default IP is 192.168.1.250, you have to set a manual IP to your machine in the same subnet, say 192.168.1.1 with default subnet mask of 255.255.255.0 and leave remaining fields empty.
once done, you may be able to access its web based utility now.
hope this helps
Feb 12, 2012 | Linksys Computers & Internet
How do I reopen my nat for xbox live
1> Go to your xbox dashboard and locate the "Network settings" section.
2> Select "Edit Settings" and change your IP setting to Manual.
3> Enter the following settings depending on your router type (Credit goes to http://live.tommccann.net):
Linksys
IP Address : 192.168.1.250
Subnet Mask : 255.255.255.0
Gateway : 192.168.1.1
DNS : 192.168.1.1
D-Link
IP Address : 192.168.0.250
Gateway : 192.168.0.1.
DNS : 192.168.0.1
4> Next open your internet browser and select the address bar.
5> Enter the 192.168.1.1 (If you use D-link 192.168.0.1)
6> A box will show up asking you for an ID and password. (your parents may have changed it)
Default ID- admin
Default Password - admin
7> Locate the "Applications and Gaming" tab, then click "Port Range Forward"
8> Forward both UDP and TCP
88
2074
3074
9> test your connection and if it should be open.
Apr 11, 2011 | Microsoft Video Game Consoles & Games
I hooked my linksys E1000 Router to Samsung 3d TV (Wired), but the TV doesnot detect the internet speed, on my laptop (Wireless) is 144Mbps.
you may need to sign in manually,those tvs sometimes dont pick up dns addresses of routers automaticallty
plug in your cable into your laptop
go to start/accessories/command prompt
type in ipconfig
scroll up till you see ethernet
take down your ip4 address,itll look something like this xxx.xxx.xxx.xxx (change the last number to something in the range of 1-250) your subnet mask ad default gateway
plug back in your line to your tv,go to manual enter settings
enter in your ip (with the number changed at the end) your subnet mask and your default gateway number for your dns/gateway if required
if you need more help try customer service on the samsung american site,theyre really good at answering any quick email queries :)
Mar 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I can not get it to work at all. Is there a CD I need to get this set up? I have a Linksys wireless G router and the Belkin F5D7130 plugged in to it. But I have no range.
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Feb 21, 2011 | Belkin F5D7130 And F5D7010 (Bundle)...
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
I cannot instal my router.
you can install your router as long as it is compatible with your pc,, and first thing you nedd to get is the ip addresss of your rrouter and subnet mask and ns settings.. then go to your tcp/ip settings and manuall y configured using the ip address, subnet mask and dns settings of your router.. then ready to go..
Dec 26, 2009 | Linksys WRT160N Wireless Router
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Can not connect to internet with the wrt320n but can with wrt54g
check the ip address, subnet mask, default gateway of the server computer then fill it up to ur comp same as the derver comp except the ip address change the ip address then try.
Oct 22, 2009 | Linksys WRT350N Wireless Router
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
