Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
WD7040 Wet Dry Vac--Do I need a special filter to use this as a wet vac? I can't find the manual
SOURCE: shop vac Wet/Dry Vacuum 2.0
How do you make a Shopvac wet/dry vacuum blow out air
Posted on Feb 08, 2008
  • 8404 Answers
SOURCE: what if i use my wet dry vac to pick up water
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Posted on Oct 13, 2009
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
ftw1952
  • 10319 Answers
SOURCE: Where can I fet parts for a Genie SV300Q wet/dry
Depending on what parts are needed Home Depot for instance carries parts for these
Posted on Apr 13, 2010
SOURCE: how to set up wet dry vac for water pick up
you take the filter off and empty it.
Posted on May 01, 2010
Where do Ifind replacement filter for my wet dry shop vac
tons of sellers on Amazon with good prices. just make sure you get one for "wet" if you plan to vac liquids.
Feb 21, 2015 | Shop Vac Vacuums
Do you need a special filter for wet application
Yes. The following site shows the filters and which is used for what. Due to potential motor damage, I wouldn't use it without the proper filter.
http://www.shopvac.com/shopvac-accessories/Departments/Wet-Pickup.aspx
Jan 03, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
Jul 08, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I did not get a manual with my vac. I am trying to soak up water from a water tank leak and water seems to go right trough the vac and water is coming out the blower hole. the tub is not full.
There is a special sock that you need to buy for it. You can run the paper filter if your in a pinch but after that one time, that's it, that filter is ruined.
The paper filter is for dry vacuuming, the foam filter is for wet vacuuming, You have to have one or the other in place.
There are two ways to snap the cover onto the basket, only one is the right way.
Look to see that the baffle is facing the hose inlet hole.
Apr 22, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
What if i use my wet dry vac to pick up water without a filter
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
67 people viewed this question
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
Tim Hunt
Tim Hunt
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
