Question about Nintendo Super NES Console
When plugged in no light - Nintendo Super NES Console
    President:
  • 894 Answers
Well it might just be the fact that it has died on you and is dead now so you should buy a new console then.
Posted on Jul 04, 2011
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Glow plug light in cab do not light up and engin do not start
check the relay for the g-plugs as it is not supplying power to the glo-plugs. Check that there is power getting to the relay to energise it to get power to the plugs.. Probably a fuse is blown
Nov 22, 2013 | Tata Cars & Trucks
How to plug in led lights in a water fountain
never seen one but if you look really hard im sure you will find the plug in it is most likley close to the power inlet these lights run off dc power converted from ac power there is a driver somewhere that has the plug in
May 29, 2012 | Home
I had a failed tail light which I replaced but ever since then the glo plug warning light is constantly on but the glo plugs are fine and the car starts easily even on cold mornings on my 2002 C 270. How...
Dear Sir Glow plug light is on it didn't mean that glow plug faliuer, it mean the power supply is continusly on to glow plug, car will start good even incold condition,please check glow plug timer or show it technician ,but it can cause glow plug failuer in future. Thanks.
Oct 17, 2010 | 2002 Mercedes-Benz C-Class
The fan works great, but the light does not work?
are they both on the same switch?
have you checked the bulb it self or the socket that it goes into?
have you checked the plug in the fixture for the light? plug the fan into the light socket plug to check and do the same for the light - plug into the fan outlet...
have you checked both the neutral and the hot for the light plug?
Feb 18, 2010 | Broan-NuTone (668RP) Fan
F250 Diesel will not start cold . Has power to glow plugs for short time ,but will not start 1986 modle.
Hello philkatkiele: My name is Roger and I will help you. First thing you need to check is the glow plugs. They will need tested individually. Un plug all 8 glow plugs. Take a test light and hook end to the positive battery cable. Touch opposite end of test light to the terminal end of the glow plug. The test light should light. Touch all 8 glow plugs. Ant that do not light are bad and will need replaced. If glow plugs are burnt out then the controller will flash wait light to early or very fast. The wait light should be on for approximately 10 seconds.If al glow plugs check ok then I would suspect the glow plug controller as the problem. Also if the temperature out side is below 40 degrees the truck should be plugged in. This will help to make the engine start easier. Should you need further help please just ask.Please rate the answer as this way I know it was helpful. Thank You for using Fix Ya. Roger
Feb 15, 2010 | 1986 Ford F 250
1992 F250 7.3 idi diesel glow plug relay has power to two large posts and one small post and the second small post pulses when activated. I checked ground to engine and seems to be gounded fine. Any ideas...
Have you checked the glow-plugs? On that system if one glow-plug is burnt up than it will not let the main relay in the controller to kick in.
Check all the glow-plugs make sure they are working.
The easiest way to check them is with a regular 12v test light.
Hook up the negitive end (aligator clip end ) to the battery + terminal and than with the other end of the test light ( pointed end ) touch each glow- plug connector tip ( with the glow-plugs harness connector removed ) and see if the test light lights up.
If the test light up--- glow-plug is good. If not than the glow-plug is bad--burnt out .
Feb 13, 2010 | 1992 Ford F250
1995 ford 7.3 litre diesel glow plugs
the best way i have found to test glow plugs is to disconnect the wire to the plug and get you 12volt test light and put your negitive lead of the test light on the positive battery cable so when you touch the test light to any ground the light will light. so now go check your glow plugs and if you have one that doesnt light the light its burned out.
good luck
Oct 27, 2008 | 1995 Ford F250
Nintendo Super NES Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
