Question about Dell Axim X5 Pocket PC
All I get from my Axim x30 is the align screen. When I tap all the crosses it just stays in the middle but I dont get the home screen, not even after a soft reset.
Take a credit card or bisiness card and slide it in between the edges of the screen gently this should fix the problem if not open it and clean the touchscreen contacts
Posted on Aug 29, 2010
Dead pixel line?
Hi, The problem with pocket PC is that you can't do something to test and find if the problem comes from the display or the graphic processor. If the device is not too old, you can try to repair it. In case that the device is more than 10 years, buy a new one. Sorry.
May 30, 2017 | Dell Axim X30 Pocket PC
Is my Axim X30 compatible with MS Office 2007?
If you save the document in word 97/2000 it should work with the X30 version of word.
Aug 14, 2009 | Dell Axim X3 Pocket PC
My pocket pc dosen't work no touch screen works
check on ebay for a touchscreen (or a broken x3 or x30) not hard to fix. this model is great for repair, the lcd and touchscreen have seperate ribbons. a small "torx" driver can be bought at home depot for about $6
Jun 25, 2009 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
X30 time error scynchronization
Have you got the correct time zone selected in the Regional Settings on the Axim?
If you have the time showing on your today screen click on it and you'll be presented with a screen showing which zone you have.
Mar 17, 2009 | Dell Axim X30 Pocket PC
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Getting past the 'Align Screen'
Had the same problem starting about 3 months ago with my Axim X5. Couldn't get the touchscreen to respond in order to input my password. However when I sync it to my computer I had better success at getting the touchscreen to work and respond. Tried the business card tip of sliding it between the touchscreen and metal cover/frame of the PDA and now it seems to work even better. Great tip. Hope it becomes the more permanent fix for getting my PDA touchscreen to respond. Mack
Jan 28, 2007 | Dell Axim X5 Pocket PC
Align screen loop?
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Sep 14, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
179 people viewed this question
Alun Cox
