Question about Whirlpool Calypso GVW9959K Top Load Washer
What does LF stand for in the display window?
    President:
  • 1,554 Answers
It means long fill and it flashes when the water fill time exceeds ten (10) minutes and the water valves are turned off. Press STOP/CANCEL to clear the display.
It is likely that the water inlet valves are not working. Check if there's water in the tub when the fault code flashes. The water inlet valves are not working if there's no water in the tub.
Posted on Aug 24, 2010
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
ERROR COAD LF, what does it mean?
Final forth ;-0) (the F could stand for Filter or Fill or LF for Lock Fault ) Hi from retired Englishman in SW France,
Sorry but you have posted at least 4 problems but against different makes and models which makes it difficult to define what your particular 'LF' stands for- different makes, models, often different meanings so here is a practical answer!.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
When heavy duty laundry is done it washes and rinses,but when light washes are done it washes but doesn't rinse, LF comes on the controll panel.
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on. Make sure your water supply is turned all the way on and that you have good line pressure. If all that is ok, then I would replace the water valve on the machine.
Here is a link to the part you need.
Nov 25, 2010 | Whirlpool WTW6600SW Top Load
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LF code comes on frequently
I had the same problem. I pulled the drain hose out and it made a strange gulping noise, as if it was plugged up. Now it works fine. I think LF stands for low flow. Maybe your drain isn't working right.
Jun 19, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What does this key do?
LF means line feed. This was a common key on typewriters. Now we just use the "Enter" or "Return" key.
Return meant the return of the carriage (the part on the typewriter that holds the paper and moves side to side as you type).
Basically, this just starts a new line for your text.
You can see this by typing a text message then add the LF and keep typing.
You can see the above text by scrolling with your finger.
Apr 08, 2009 | LG Dare VX9700 Cell Phone
Kenmore oasis he
load full. to much load , be sure the legs are properly level . you can go to sears.com and download , the owners manual directly from their web site
Jun 10, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
