I have an att uverse hook up (tv 675 watts, a power box att.,what cyber do I need for a power outage of 1 hour? I also have att uverse with tv 123 watts, power box, and a gatewas to my computers what do I need for that one?
  • 1 more comment
  • jack leslie Aug 24, 2010
    I repeat what cyber ups do I need ??? the number please
  • jack leslie Aug 25, 2010
    is there something wrong with my question that all these experts can't understand? Which cyberpower ups battery do I need for a 675 watt tv and which do i need for 123 watt tv for one hour back up of power outage. they are not connected, seperate rooms. example I have a cyberpower ups no. 375 SL and an APC BE550G
    thank you now I know which to order. you gave me what I asked for and not a bunch of numbers.
  • 5,807 Answers
Most UPS can only have a limit of about seven ( 7 )
to twelve ( 12 ) minutes, depending on the " Load.".
• If you intend to use it for more than the specifications then
may need to :
a ) add additional battery ( with higher capacity )
b ) Modify or add additional automatic chargers.
( for the new battery that are to be added )
Here are the units :
OL3000RMXL2U
http://www.cyberpowersystems.com/products/ups-systems/smart-app-ups/paragon-series/OL3000RMXL2U.html
OL2000RMXL2U
http://www.cyberpowersystems.com/products/ups-systems/smart-app-ups/paragon-series/OL2000RMXL2U.html
or other brand of Inverter which can supply a Max of 2000 watts.
or more
plus a large 12V or 24V automotive battery
plus an automatic charger
Posted on Aug 26, 2010
  • 11,800 Answers
There isn't one large enough to handle even the smaller tv for an hour.  At best you can get about 5 minutes.
For the big tv - CP1350AVRLCD
For the small tv - CP685AVRLCD
If you really need an hour of backup  power then you need to modify yourself the units - just open their cases and attach to their original lead-acid battery a big, deep-cycle 100Ah battery.
Posted on Aug 25, 2010
  • 12,061 Answers
Ok well usually there is a simple formula to work this all out. We do that by figuring out how many Kilowatt Hours of use we need to be protected for.
In your case, together, you have 675 Watts, + 123 Watts = 798 Watts. Well the best case for you will then be for a One Kilowatt/Hour Inverter. To power them all.
675KW/H & 0.123Kilowatt/Hour, to have enough "headroom" a One Kiowatt Hour unit will suffice.
Divided up, A One Kilowatt unit for the TV.
Another 1/4 kilowatt, or 250 Watt unit, for the other unit.
However there is NO reason why they cannot ALL work from one central unit.
The UP time is simply dependent upon the capacity of the backup batteries. These need to be again worked out by how long you expect to use it.
You would need at least 100 AMP/HOUR of battery, @ 12 V DC, of, power to last the distance.
Hope this helps.
  • 17,129 Answers
I understand that you require an uninterupted power supply (UPS) for your equipments. Looking at the power requirements of your equipments, I would recommend a UPS of capacity 2KVA for delivering safe power.
You will require a battery of capacity 100AH to deliver the said load for about 2-3 hours. It is always better to take a calculation that is higher in value so that the demands are met easily.
Even a 80 AH battery would be enough but I suggest you can check the cost and decide so that you get the extra time in case of an emergency.
You must check on the make/ models of UPS available in your area and estimate the cost.Please evaluate the installtion which can be done easily.
I hope my advice helps..
Posted on Aug 24, 2010
  • Donald DCruz
    Donald DCruz Aug 25, 2010
    for the 675 you might need a 80 Ah and for the 123 you might need a 40Ah.
    But it would be wise to have one unit and connect with a wiring change.If possible with a larger unit the LT house circuit can be connected.
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
I have a hitachi 53SDX89B model rear projection. I was recently trying to have it connected to ATT Uverse TV. Every time the tech hooked the DVR receiver to one of the inputs, it knocked out the service. ...
Hitachi 53SDX89B is September 1999 model as its mentioned on its service manual that I have.
Since tv is too old so I'm afraid, no spare boards or parts would be available any more to fix its AC leaky current issue that damaging ATT U-verse service. (power back feeding out, we call it AC leakage).
There is one solution for that problem, buy Isolation Transformer and plug your tv in it, that will cure AC leakage from your tv and wont hurt any thing attached/ connected with this tv. Your tv consume 245 Watt power while working so 500 Watt isolation transformer would be good enough to keep turn On tv for hours/ days.
Below is an image of basic isolation transformer and click HERE to get required 500W isolation transformer.
Hope these info will help you.
Thanks.
Jul 19, 2010 | Hitachi 53SDX89B 53" Rear Projection...
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
I have 3 att uverse cable boxes...1 being the dvr unit. The room with the dvr unit only shows a black screen with live tv? When I go to watch a recorded show it works in the other rooms but is a black...
Is the cabling from the satellite receiver to the DVR hooked up right. It sounds like it's in single mode, but with the coax cable put on the wrong way.
Nov 23, 2009 | Computers & Internet
Att uverse receiver hooked up to sharp aquos tv, remote quits
first try new batteries and be sure you have pressed the AT&T mode button at the top left of the remote - if you still have issues then on the sharp tv menu - turn off any energy saver mode, Optical Picture Control, taking the picture mode from dynamic or vivid to standard, and if that doesn't work - try changing the backlight settings if your tv has one.
Aug 23, 2009 | Denon AVR-1908
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
