Question about Kitchen Ranges
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then it operated well. The door needs a reset.
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Posted on Aug 26, 2010
Hi,I have a Digidoor 3 motor & it open & closes as normal but after the garage door is closed it drops the chain about 15cm then slums it back into the track. Can anyone help me out please?
will need a digi door or roller door mechanic in your area
head office ? use contact us
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
three motor makes it harder
door drop is 15 cm is not a good thing
chain system needs to be retention ed
motors synchronized
event track may need to be re aligned
Oct 31, 2016 | Building Materials
Where can I get a digidoor 1 garage door motor ?
I found a site that you may check out go google -type in www.hydrodoors.co.za/products
they claim to be the home of digidoors. they have an e-mail , sales@digidoor.co.za and a telephone no. 0114749060
even if they are not close to you maybe you can purchase on line and have it sent to you.
Feb 17, 2015 | Cars & Trucks
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
How to re programme my Digidoor III garage door motor?
Did you check it engages the end switches?
Oct 07, 2014 | Building Materials
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
I have a Digidoor garage door that closes halfway and the opens again however when you apply a little pressure to the door the door closes completely The entire shaft was cleaned and lubricated but still...
There probably is a dent along the shaft either in the remaining region or the already occupied region. You should open it completely and verify that the shaft is uniform. There could also be a deformed roll in the part of the door that enters the vertical part of the shaft around the time the door stops closing.
Nov 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
1,756 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
