Question about HP PSC 2410 All-In-One InkJet Printer
The screen says to remove and check print cartridges. I have done this several times, cleaned them and it still tell me to do this. It won't reset and print.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Canon Printer MX410 will not print after reloading ink cartridge
PG510 and CL511 cartridges have a memory chip which records the number of pixels printed to give an approximate ink level so it won't know if you have added more ink. These levels cannot be re-set. The error message on computer screen should give instructions to continue printing with an "empty" cartridge which normally involve holding the Stop/Reset button on the printer for more than 5 seconds whilst the message is still on the PC screen. You may have to do this once for each of the 2 cartridges.
Sep 21, 2017 | Canon Pixma MX410 All-In-One Printer
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
Epson 760 won't print, but there's ink in the cartridges!
You may havbe to invest in the cleaner cartridges.
You can try this though.
Bring the cartridges to the middle and unplug machine.
Remove carts and take 5-6 drops of ammonia and put it where the ink would pass through the head.re-install cartridges (Do not plug in)and let it sit an hour or so.
Plug it in and do a nozzle check after the machine has purged itself.
Jul 24, 2009 | Epson PowerLite 760c Slide Projector
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
My printer screen says there is a cartridge error.
The contact between the ink cartridge and the printer must be clean for proper functioning. If any dirt, ink or paper dust is on the contacts, the printer may indicate that the ink cartridge is bad. To ensure a clean contact, follow the steps below:
Step 1: Remove and re-install the cartridge
  1. Turn the printer on; open the printer to access the print cartridges.
  2. Remove the suspect cartridge(s) from the station.
  3. Re-install the cartridges in their stations.
  4. Close the printer.
  5. Turn off the printer for a few seconds and then turn it back on.
  6. Print a test page following your printer’s instructions.
  7. If this does not work, please proceed to step 2.
Step 2: Clean the contacts on the printer and the ink cartridge
  1. Turn on the printer; open the printer to access the print cartridges.
  3. Using a clean, dry lint-free cloth wipe the contacts on the print cartridge from top to bottom. The contacts inside the printer may also need to be cleaned. Please refer to your printer’s manual or the manufacturers’ website on how to clean the contacts.
  4. After cleaning the print cartridge and printer contacts, re-install the print cartridges and close the printer.
  5. Print a test pattern to determine if the problem has been fixed; if not proceed to step 3.
3.Reset the printer
  1. If the problem has not been fixed it may be useful to perform a "hard reset". This can correct an electronic flag setting inside the printer telling it that the print cartridge is problematic. Please refer to your printer’s user manual or the manufacturer’s website for the correct "hard reset" procedure for your printer. Often times it simply involves turning off your printer and unplugging it for at least 30 seconds.
  2. Print a test page to determine if the problem has been resolved.
  3. If the problem persists, you may need to purchase a new print cartridge.
All cartridges being repeatedly refilled eventually do fail. Some cartridges/printers may encounter an unavoidable mechanical or electrical failure which is unrelated to refilling. Check for physical damage on the cartridge. Look at the print cartridge and see if there are any cracks, tears or missing elements. Any one of these can cause a failure. In these cases, you will need to purchase a new cartridge and start the refill process again after it has run out.
If these solutions do not work, we recommend that you visit your printer manufacturer's website or talk with their technical support organization. If you think the refilled cartridge might be bad, take it back to your refiller and have them re-check the cartridge.
Jul 16, 2009 | Dell A940 All-In-One InkJet Printer
Black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Jan 18, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
Dec 03, 2007 | Epson Stylus Photo 950 InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
