Question about Hotpoint 24 in. DF55 Free-standing Dishwasher
Technika Diswasher Couple month ago  we got pump replaced and worked fine, however now it leaking at the front maybe even at the back
Hi ,I have a leaking problem with aTechnikaTDX20W and have discovered from service that it is the spray arm which has cracked along the seam edge . This then spays the door seals and they leak. unfortunately the part is out of stock which seems to be a problem with Technika. If anyone can help with a new spay arm I would appreciate it. I have tried te glue it however didnt work. The dishwasher is only three years old and I am considering buying an Australian made one to ensure parts. Worth a check of yours. Regards,Brian.
Posted on Jun 03, 2008
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
Car cranks but wont start is it the fuel pump if so is there any thing i can do
even with a fuel pump somewhat working I've seen vehicles start but run really sloppy. try getting your battery checked for correct voltage, could have a dead cell, very hard to notice cause all seems normal. could be fuel filter that's an easy enough fix. Fuel pumps **** cause if their inside the tank, then you have to replace the whole tank other then that there's nothing you can do. I had a problem in the front tank of my truck, idled fine but then when driving got really ugly, lucky for me I had gas in my back tank and got home. Few months later i was broke and of course when the front pump went, it went on a full tank so driving home on fumes I switched to front tank and whatever the blockage was seemed to be gone and she's been working ever since. sorry bout the essay, but it's not time to throw out hope yet. Oh! don't know location or weather conditions but it's a nightmare here in Calgary (-36C), maybe just plug it in for a couple hours. I'm hoping for ya
Mar 05, 2011 | 2006 Pontiac G6
Coolant leak from around the trany pan.
bottom left is drivers side. ck hoses, heater hoses. maybe a pressure test may show where the leak is.
Oct 17, 2009 | 1997 Chevrolet Cavalier
2002 Jeep Grand Cherokee leaking coolant and power steering fluid
Just a heads up, $10 bucks will buy you a seal kit for the P.S. pump. I topped mine off for a couple months, then the oring on the high pressure line (from pump, front center) blew and dumped the reservoir in a matter of miles.
The line can be a stinker to get off, recommend driving the car for a few minutes to heat up the pump a little. Don't forget the 20MM wrench.
Feb 18, 2009 | 2004 Jeep Grand Cherokee
1993 altima will crank but will not start..
replace the distributor oil is leaking into the electronics of the distributor and shorting out pull cap back off and look and see if oil is leaking out
Jan 24, 2009 | 1993 Nissan Altima
94 town car leaking coolant
you have a leaking water pump... there is a "weep" hole at the bottom of it and when the inner seal goes bad it starts slowly leaking out of it as a warning sign to replace it. It will do that for a few days, or months even, until it starts leaking profusely.
Nov 24, 2008 | 1994 Lincoln Town Car
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hotpoint 24 in. DF55 Free-standing Dishwasher Logo
327 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
