Question about Vacuums
We have eureka forbes trendy steel vacuum cleaner of canister type but we dont have the instruction manual.how to join the parts and how to use.
SOURCE: majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
Posted on May 25, 2007
reddevil6
  • 1673 Answers
SOURCE: repair manual for Eureka 4335 Type D upright vacuum cleaner
Maybe these pictures will help:
Posted on Feb 17, 2008
reddevil6
  • 1673 Answers
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
  • 33 Answers
SOURCE: Eureka Capture Vacuum
1 ) That unit cannot shut off the airflow to hose while unit is used in upright position. The hose is in constant use, whether you are using attachments, or vacuuming the floor.
2) It does sound like you have a clog somewhere in the unit. Most often it is the grey filter screen is full, (which is located just above the dust cup...instructions found on sticker on back side of dust cup) which causes everything to clog or back up. You should check this piece every time the dust cup is emptied.
3) To check for clog in main hose, remove the square clear hose adapter (with a phillips screwdriver) from the back of the unit and pull out the grey plastic attachment end of hose from the side of the unit by the duster, and unwrap the longest part of hose from vacuum and lay it on the floor. Get a quarter or a nickel and while holding the clear square adapter end of hose up , drop the coin into the hose, shake the hose to see if the coin will roll all the way out the other end of hose onto the floor. If it comes out, re-attach the hose adapter , making sure the little foot is in place, and with the dust cup locked in place, turn the unit on, test suction at end of the hose, it should be strong. But, if itdoesn't come out, there is a clog. The grey plastic hose retainer at the bottom of the unit is open where you can stretch it over the hose and free the hose from the unit.Take something like a mop handle or broom handle,(I've also found a long dryer lint brush to be helpful) insert into the hose to break the clog loose. Repeat the coin test. When the coin comes through, reattach the hose.Test for suction.
4) To test the lower portion of hose for a clog (from the duster unit to the brushroll area in base) with the attachment end of the main hose out of the hole, you should be able to look down the opening and see into the lower portion where the hose curves into the base. Drop your coin in the opening (not in the duster tube) it should, with gravity, roll out to the floor. However, it may stop at the brushroll, so tilt your unit forward, and side to side to see if it comes out. If that doesn't make it come out, there is a clog in that lower hose.
5) To clear the clog, recline the handle all the way down on its back( again like vacuuming under a bed) roll the unit on its "belly", you should see the lower hose straighten out more, Insert something blunt into it, broom handle, or a bent wire coat hanger (bend to protect hose from puncture) and you should be able to clear the clog. If it still wont clear the clog, remove the 4 screws from bottom of unit and take hood of unit off to see the opening of bottom end of lower hose, near the brushroll. Clean out clog from that end. Once cleared, stand unit upright, re-test with the coin until coin rolls out freely. Put all parts of unit back together.
6) Make sure the height adjustment pieces are still attached to bottom of unit. (the plastic piece with 2 wheels and a spring) Reset this component, by reclining the handle in normal operating position, lean down turn height knob on hood to the highest carpet setting, and flip it slowly over to the bare floor setting, do this back & forth 4 times... over & back is 1, etc...then determine your carpet height...( berber is like normal carpet ) set the knob (with handle still reclined) on the middle setting, then place unit back in upright position. Test the vacuum for approx. 1 minute. While testing the unit, look into the dust cup and see if the dirt is swirling. If it isn't, then check the dust cup filter,(under the dust cup) to make sure it is clean. If it is coated with dirt, etc...,remove the filter tray , pinch the foam filter and pull out of tray.Tap the filter over a trash can, or replace it if you have a replacement foam filter handy. Replace foam filter in the tray, replace filter & foam into unit, close the lid, replace the dust cup and lock in place. Re-test vacuum.
7) If all the above steps are followed, this should prevent future clogs in unit.
Posted on May 17, 2009
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
I need to replace the belt on my eureka canister vac. have the belt and screwdriver, now what? how to get the housing off? etc.
Can you please specify the type of model that you have? The model that you listed this repair question under, the S3686 doesn't even have a belt on the vacuum cleaner. The model number can be found on the bottom of the vacuum on a sticker that also contains the serial number.
Please just use the clarification request form here on Fixya, and I will then even take some pictures on how you need replace the belt.
Apr 03, 2010 | Eureka Sanitaire S3686 Bagged Canister...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Broken canister latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=604237
Posted by nestara on May 17, 2008
The little plastic latch that holds the canister in place (the lower part that is recessed) is broken. I need to find a new part to replace it. I cannot seem to find one so far...most sites just offer replacement bags/filters....etc.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Sorry you are having a problem with the replacement parts for your vacuum but if you contact the Eureka Factory Service line of which I will list below, they will either supply you with the part or give you a contact factory dealer that will get you the part and also you may as for a schematic or and owner’s manual in order to see how to repair the part. If you have further questions, feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Eureka canister vacuum model 6865- cleaning
70227 is the part number for the owner manual, but you would have to have it order it. You can call 1-800-282-2886, this is Eureka's customer service, they don't have it in their data base, but maybe they can find something for you.
Mar 10, 2008 | Vacuums
Majestic filter queen canister vacuum cleaner
Apr 13, 2007 | Filter Queen Cheetah II Ash - MU305...
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
