Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
I have a Robo Kleen robotic pool cleaner, it still moves around but is no longer picking anything up. The bag is clean. Can I purchase a pump for it?
  • 640 Answers
You should be able to purchase pumps for these automatic pool cleaners from a pool supply company, but I would take it to a professional first. It could be something that is easily fixed without purchasing an expensive part.
Posted on Oct 07, 2010
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My Robo-Kleen does not seem to clean up anything form the pool floor. this is the first time is used it and was wondering if i missed anything. it moves around, but at the end of the cycle the filter bag...
Here is a copy of the users manual for these pool cleaners. I would go over the installation instructions again. You most likely do not have something connected properly. The button that you are talking about should be the one that controls wheel movement, but that will not have anything to do with suction. Check all of your connections (specifically) to make sure that you don't have a leak somewhere.
Aug 02, 2010 | Smartpool Dolphin Robo - Kleen Above...
My robo keen pool cleaner is not moving either forward or backward
This is a pretty common problem with these automatic pool cleaners and it usually has a very easy solution. First, even though this seems obvious, make sure that the cable is uncoiled completely and is not blocking water flow. Secondly, make sure that the filter bag is clean and that the impellers are not blocked. Finally, make sure that there is no debris/leaves caught in the axle bearings of the wheels.
Jun 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen stopped sucking
Make sure that your filter bag is clean and free of obstructions. You will also want to check your impeller to be sure that nothing has jammed it. A jammed impeller actually occurs pretty frequently on these automatic pool cleaners.
Apr 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
Need a motor. were can I buy. motor is frozen (robo kleen)
if it drives but does not pick up anything
then thats the motor with the prop, water gets in it
but there are two screws with metal plate on back of motor
and a round plug then a green plug to let the water from your pool out
Sep 26, 2009 | Smartpool Dolphin Robo - Kleen Above...
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
Wondering if a robo-kleen robotic pool cleaner can be used in an inground pool?
You will find it won't climb walls, but should clean just fine on the bottom area.
S. Christian dansker01@msn.com
Jun 05, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
202 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
