Question about Olympus C-180 1.70x Lens Converter
Hi - is it possible to remove the lens from an Olympus C-7070 camera? I want to try to fit it on to an inverted microscope with a bayonet fitting. Thanks, Paul
    Brigadier General:
  • 3,006 Answers
The lens is not designed to be removed and the camera will not function if you do manage to do so as it will report a lens error. To avoid this will involve bypassing various microswitches, simulating missing inputs and making other custom modifications to your camera. It's not impossible but you'll be on your own with the modifications, adapting and inventing as you go.
Ideally you either need a suitable SLR with an adaptor, or a camera which will accept an adaptor onto the front filter fitting (not all compacts and bridge cameras have them though).
You'd best contact Olympus directly for suggestions: they're a major microscope manufacturer and have always had the best solutions for using their cameras with microscopes. They have in the past produced a surprising number of microscope adapters for their models and have often produced special versions of their cameras designed solely for use with microscopes, endoscopes and similar non-standard applications.
Posted on Sep 04, 2010
Just aquired an old olympus inverted microscope which needs cleaning and spare parts. The microscope is a binocular inverted microscope I would guess to be around 20+ years old it has a working light...
Olympus makes good microscopes so you have done well and stereo microscopes are so much nicer to use than singles. As far as cleaning the lenses goes, buy a good quality camera lens blower brush and also a can of compressed air like the ones used for computers. Blow any loose dust hairs etc off with the can of air and then use the brush for anything remaining. If there are fingerprints or grease on the lenses then clean them using camera lens cleaning fluid and lens tissue but make sure all debris and dust are removed first or you may scratch the lenses. In general try not to use anything more than air and a brush unless absolutely necessary. Another option for removing fingerprints etc is to use a "lens pen" with caution. The ones sold for cameras work well but may be too large. They make some smaller ones for cleaning camera sensors and those might work better for the relatively small microscope lenses or just cut the regular lens pen disk to make it smaller. It is just as important to make sure the lens is dust/debris free when using the lens pens.
Low power stereo microscopes often allow you to put on a single magnifier lens in front of the main objectives to increase magnification. Do a bit of searching to find what are options for your model.
May 26, 2017 | Olympus Science & Laboratory
I have an Olympus PME microscopewith a 35mm camera(bayonet fit)Can I fit a digital camera here instead? Thank you.
be sure all connection and ports match with the existing Olympus.
melnavz
Aug 04, 2008 | Cameras
What other brand lens fit this camera? Thank you. the camera is a P30 35mm
All Pentax bayonet mount lenses.(Third party) lenses:Vivitar,Sears,Tamron,Later Chinon,...In Reality almost all third party lens maker have produced bayonet mount lenses,and most of them are marked with a PK.Best third party lenses are Vivitar.Hope this helps.
Feb 07, 2011 | Pentax P30T 35mm Film Camera
Is it posseble to use a vivitar lens of analog olympus camera on a digital canon camera
It depends on the lens. If the lens has a fixed mount for an Olympus, then no, it will only fit on Olympus cameras. If it has a removable T-mount, then yes, with an appropriate T-mount for Canon or most any other brand.
Sep 13, 2010 | Vivitar Cameras
I want to get a manual also I want to purchase a wide angle lens for the c-7070 olympus camera
Manual can be downloaded free from here ....
http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/CAMEDIA%20C-7070-_E
A typical wide / tel lens kit listed on eBay. Note that either / both lenses require you to screw an adaptor tube around the existing lens, so that the lens extender mechanism can continue to function properly. (This kit includes it - some do not).
http://cgi.ebay.com/Tele-Wide-Angle-Lens-kit-for-Olympus-C7070-C-7070-52_W0QQitemZ360184089696QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item53dca50c60
Hope this helps
Mar 05, 2010 | Olympus Cameras
Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter.  There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
Nov 25, 2009 | Pentax ME Super 35mm SLR Camera
Hi can this OLYMPUS TCON-14B TELE EXTENSION LENS fit my olympus e410 can you let me no thanks
no it will not.. it is designed as an attached to a fixed lens for some point and shoot cameras
Sep 07, 2008 | Olympus Cameras
Optic lens tube separation
image.php?productid=16148sir,your microscope tube with the eye piece is screw joint with microscope body. Rather part is friction fitted as well as there is a proper place to mount it.you can do the gluing but first of all be clear that part should be not a movebale part other wise you will have dificulty for fine focusing.
for the further quotation dont be hazitate,
INDRAVIJAY
Feb 13, 2008 | Tasco 750 Monocular Microscope
Attaching non-Olympus lenses
The E-500 body has a "bayonet" twist & click attachment for the lens. There is no way that a simple screw threaded lens can attach to the camera directly. The lens that you have are designed to screw into the front of the original Olympus lens. I have seen some of these adverts on auction sites and they are worded something like "The wide angle / Tele lenses are simply mounted in the front of the Olympus EVOLT E-500 / E-330 / E-300 standard ZUIKO Digital EZ 14-45mm lens, or any other lens with 58mm filter thread." Which maybe isn't clear enough. So the bottom line is that you need an Olympus lens to use the other lenses you have bought. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Olympus EVOLT E-500 Digital Camera
Microscope
No. Your camera is not compatible with a microscope, but Olympus does manufacture a DP-10 microscope digital camera system designed specifically for medical and industrial use. For more information about this, please contact the Olympus Precision Instrument Division at 800-446-5967.
Aug 31, 2005 | Olympus D-500L Digital Camera
Olympus C-180 1.70x Lens Converter Logo
145 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
