I have a brand new Epson C120 printer. I have it plugged in to a triple tap outlet adapter. I also have a brother printer plugged into the same adapter. Yesterday i plugged a vacuum cleaner into the adapter as well. This morning i tried to use my printer but kept getting an offline message on my computer. The green power light was on so i tried to turn the computer off and back on. It will not power back on. Is it possible i fired something with the vacuum cleaner? ay help would be appreciated.
  • rickrenta Aug 24, 2010
    IT IS THE PRINTER NOT THE COMPUTER THAT WONT TURN ON. I PLUGGED IT INTO ANOTHER WALL OUTLET AND STILL NOTHING. IM PUSHING THE POWER BUTTON BUT GETTING NO RESPONSE.
    OK THANKS FOR YOUR HELP
  • 4,737 Answers
It's not so very clear about your problem. I am not sure whether it the problem with your printer or with the computer that doesn't power back. In the first part of your query, it seems your printer is having a problem, but when we go down to the 5th line "The green power light was on so i tried to turn the computer off and back on. It will not power back on" I got confused with it.
If it's the printer, before you do anything with it, remove the cable usb cable from the computer and disconnect it from the printer. Now unplug the power cord from the printer, and connect it (the Dc adapter and the printer) to another socket (only to check that the outlet adapter is not the problem). If it works and power on on with another socket box, then the problem is with the "triple tab outlet adapter". It might have burnt out or have got overheated when you did connect the vacuum cleaner. Power jack/Socket/(Triple Adapter) easily gets damaged and burnt when a high power electric appliance is connected. It could be loose connection or if not would have totally burnt, you'll not be able to use/connect to the adapter unless you replace it.
But if in case the printer doesn't work/power on even with another Mains Outlet, then verify that the AC adapter (printer's adapter) is turned on. You'll be able to see this from the power led light indicator.
Let me know after you are done.
Good luck.
Posted on Aug 24, 2010
  • 1 more comment
  • Lebanon Raingam
    Lebanon Raingam Aug 24, 2010
    Thanks for the clarification. Well, is it possible to use another power cord? (if you can borrow it from someone or if you have extra power cable). Since this power supply unit (adapter and cord) is the main part that plays the power function, we have to start from this. If after it's not successful, you'll need to check the power supply unit on the printer but it's not easy and will be tough if you don't have the tools like screwdriver, soldering iron, soldering paste, soldering wire etc..etc..
    Sorry, I skipped one important query, is there led light on the printer adapter? or is it directly connected to the Mains socket?.
    First find/get another power adapter, then we'll be able to narrow down to the nearest suspect without wasting time.
    Awaiting
    I HAVE THIS PRINTER PLUGGED INTO THE WALL OUTLET WITH A REGULAR POWER SUPPLY CORD. THERE IS NO ADAPTER . I TRIED ANOTHER POWER SUPPLY CORD AND STILL NOTHING.
  • Lebanon Raingam
    I am sorry to say that it must be the power supply unit of the printer (small circuit board inside the printer). It's possible to be replaced or repaired by only authorized technician. I would recommend you to contact the Service Center or the dealer where you purchased it. If it's under warranty, you'll get a replacement or they'll repair it for your free or charge (conditions apply). You can contact epson (technical issues). Open this link (click here) to directly contact Epson for technical support for your printer (only for your printer, there are many categories, this is particularly only for Epson Stylus C120 ). Tell them your problem and they'll direct you to the nearest service center or they may also send their technician to inspect the Machine.
    I wish you all the best.
    Thanks for using FixYa.
HOW DO I INSTALL MY EPSON C-120 PRINTER WITHOUT A DISK
Hello, you will need to download your drivers online, use this link to download your drivers directly from the epson website:
Epson Stylus C120 Ink Jet Printer Driver
Choose your operating system and click go to view available drivers. Click the plus (+) sign next to your driver and then click download
Jul 31, 2011 | Epson Stylus C120 Color Printer InkJet
I need a repair manual for Epson Stylus C120 printer. Can you find me one?
Epson Stylus C120 Service Manual->>Start Download
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
May 27, 2011 | Office Equipment & Supplies
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
Sep 09, 2009 | Epson Stylus C120 Color Printer InkJet
Epson c120 thinks black ink cartidges are empty.. but i just got new ones.. . and i suspect the last ones weren't empty either :( . please help!
Make sure the contacts where the ink cartridge plugs in are clean inside the printer. There may be something stuck in there. Also make sure the cartridge is fully seated in its cradle in the printer.
Jan 26, 2009 | Office Equipment & Supplies
No power to epson 1280
Well, first things first I guess:
  1. Try the printer in a different outlet (other side of room, or similar, not same power Jack)
    1. If you have power here, your issue is likely the outlet, not the printer.
  2. If the power cord has an "on" LED, check to see if it is lit up while plugged in.
    1. If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
  3. If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
  4. You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
  5. The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, but I can't tell from the epson site if this printer has one or not. (It would be a black box between the plug and printer.)
    1. This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
      1. If this is the case you will want to contact Epson if the unit is still under warranty.
-Hope this helps.
May 27, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
C120 Installation Problem
call the manufacturer immediately for ink replacement.
Jan 07, 2008 | Epson Stylus C120 Color Printer InkJet
24 people viewed this question
k24674
jasbo
jasbo
