Question about Sharp LC-37D4U 37 in. LCD Television
My sharp lc-37d43u needs a replacement power supply part # dps-178ap. I have looked everywhere for the part and no dice(yes even ebay). I need to know if there is a replacement power supply that is compatible with the tv.
  • Sharp Master
  • 8,457 Answers
Try website like Shopjimmy.com.Have the most LCD tvs boards parts around.
Posted on Aug 24, 2010
I have a Sharp Aquos LC-37d43u and when I turn the power on the picture and input show up for a second then the whole screen goes black. Any thoughts?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 23, 2015 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
My LC-37d43U won't turn on, no lights, no nothing...?
Open fuse on power supply board, or the power supply is dead, or there is no voltage coming out of the receptical out of the wall, You can hget a new power supply at b www.partstore.com take care.
Nov 03, 2011 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I have a sharp aquos 37 lcd and one day I turn it on and hear a pop sound and it went dead no power
Normally this is indicative of a faulty power supply circuit inside your TV.
The easiest way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one.
You can find a replacement circuit board on Ebay by searching for your TV's model number.
Here is a link to one currently available for about $100 plus shipping:
http://cgi.ebay.com/DPS-178APA-Power-Board-Power-Supply-Sharp-LC-37D43U-/260814504762?pt=LH_DefaultDomain_2&hash=item3cb9c1833a
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your power supply circuit board itself and confirm that it exactly matches the one provided in the Ebay listing.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
One other thing you can check is to see if there is a fuse fitted on your set.
Some models will have a fuse holder compartment accessible from the rear of the set right where the power cord enters the enclosure. If your set does not have one of these, then the fuse may be located directly on the power supply circuit board itself.
Try testing that fuse for continuity with a voltmeter (with the set unplugged of course). If that fuse has failed, then it will test OPEN. If you are lucky, you may then just need to buy an exact replacement fuse and then install / solder that into place to correct the problem
I hope that was helpful to you, good luck.
Joe.
Jul 17, 2011 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Have not got base stand to go with Sharp 37" LCD TV LC-37D65E Where can I get one? How much might it cost? Thanks
Tries websites like Amazon.com,Ebay.com to buy a used or new tv base stand.Cost might run u like $25-30 for a used one and $40-50 for a new one.
Jun 11, 2011 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
My sharp lc37d43u remote wont turn tv off or on and the power button, channel buttons , volume and input doesnt work either i just replaced the power supply can any one please help
What was the tv problems before u change the power supply board?Give me the previous problems,so i can tries to retraced the cause and give u a solution to fix the tv.
Oct 20, 2010 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Sharp agous .. no power
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Aug 30, 2008 | Sharp Aqous LC-26D5U Television
Sharp LC-37D4U 37 in. LCD Television Logo
546 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
