Question about Nikon D80 Digital Camera with 18-135mm Lens
Did not drop or hit the camera, but on the P position cannot get a clear focus as it is mostly white. Depressing the Expose button half was shows clear for a moment before getting ready to Shoot. On the Automatic position it is fine
  • Louis Shornick Aug 24, 2010
    It was the P90 not the D80, but the same applies.
    First Reset U-1 and U-2 did not work
    Reset All worked fine.
    Thank you and have a good day.
    Lou Shornick, Madison, MS age 92
  • 3,083 Answers
Since the camera focuses in the auto position, we can eliminate the focusing ring assembly as being bad. That leaves the most likely suspect to be the circuit concerned with the P function, which will most likely relate to being a slightly loose ribbon connector within the camera. Since the shutter button allows the camera to focus momentarily, the circuit has to be intermittent, cutting off. Unless you use the P function a lot, you might just be better off working around it. You can reset the ribbon connectors yourself, but of course, you'll have to partially disassemble the camera. You can check with a camera repair shop for an estimate, and then decide if it's worth it.
It could be a trickier problem than I suspect, so the cost of repair could be higher than anticipated. I would contact Nikon Support, just to see if others have reported this problem, then at least you would be pretty sure what you're dealing with. Here is their site:
http://www.nikonusa.com/Service-And-Support/index.page
Nikon is a good company, and you may get some great help from them.
At any rate, good luck, hope this helped, and thanks for using FixYa.
Posted on Aug 25, 2010
  • 10,865 Answers
Hi lou. Turn the D80 on and then go into the menu and find reset. RESET it. this will take it back to all of the settings it had when u first opened the box. If the reset does not solve the problem you will have to send it to NIKON or take it to a Nikon sercice Center as any disassembly you do yourself will void the warranty. J.
Posted on Aug 24, 2010
Why are my photos blurry
I would think that you are not focusing your camera before fully depressing the shutter button Start by depressing your shutter button very lightly until you see the outline of a small square in the middle of the view finder . At that point you are in focus . Now fully depress the shutter button and take your picture . You must do this prior to taking each photo . Remember to just depress the shutter button about half way to focus your picture image , before pressing it fully . I hope this is of some help to you.
Apr 06, 2017 | Cameras
My Nikon p80 has difficulty focusing in low light. Also, the white balance is difficult to control and most low light photos are too yellow.
Seems to be interesting.
For low light focusing problem here is the solution which works with any digital camera.
I have observed that P80 has a slow focusing symptom. If you are in TELE range that is lens out. Then you will be hitting this issue very frequently.
Check if you are not restricting that red light bulb from throwing the light on your subject.This light is to assist the camera to focus.
Try doing this. Illuminate the object with a small/capable torch. Sometimes AF assist lamp is not doing the job.
another solution is focus in small steps. move lens out a little half press the focus/snap button. repeat this till you get the desired frame. This somehow helps camera to focus difficult objects.
White Balance:
Nikon P80 has good white balance functionality. But if you do not get what you want you need to set the WB manually. Here is the procedure to set white balance manually.
Procedure:
You need to select the preset manual for this procedure. Keep a white colored object with you always. This should be of size of a playing card at minimum.
when you will select the manual white balance preset. it will show you the measure option. Keep your white subject in front of the lens and press measure such that the camera view is filled with that white object's view.
Now you are ready to go. Your Camera will take the pictures just right.
Sep 22, 2010 | Nikon COOLPIX P80 Digital Camera
Out of focus
Most digital camera now a days have manual focus or automatic focus. Try holding down the button that you would normally hit when you take a picture BUT Do NOT hold it all the way down. Hold it only half way. That should focus it (: ENJOY!
Jan 03, 2010 | Olympus FE-280 Digital Camera
When taking photos of moving items, sometimes it talkes a long time to expose and therefore I get pictures of the ground/sky etc
many cameras have a slow shutter release .. when you push the button you expect it to take a picture right away .. but the camera has to first adjust for focus and determine how much light is or will be available then set itself up .. this takes time but some newer cameras do it all very quickly .. one way to get around this is to first hold the shutter button down half way .. do this early just before your subjects are where you want them .. the camera will auto focus and set itself up .. keep the trigger in that half way position until the subject is in place .. now when you push the trigger the rest of the way down, there is very little lag ... make sure that you focus on something close to where your subject will be when they are in position .. .. another speed up trick is, if your camera has manual focus .. preset the focus for where you want it and that saves the time it takes to auto focus .. there are several digital camera reviews on the interent ..they will tell you how much shutter lag you can expect for different cameras .. that can be a great help when you are ready for a new camera or want to see where your present camera performs ..
Jul 13, 2009 | Olympus SP-560 UZ Digital Camera
SD550 camera not focusing correctly. Green focus square sometimes shows up, sometimes not, either way, it's not clear even on the digital screen prior to taking the shot. Camera does make a slight click...
to make the green square show up just press the shutter button until half (this is called the half press) when the green square shows up then it means that the camera has focused already, if not repeat the process til green square comes out you can press the shutter button fully to take picture when you see the green square...
Jul 06, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Shutter problem...
Kindly explain the problem in detail. i.e.
1) how did this happened. all of a sudden or you dropped the camera, or something else.
2)when you half press the shutter button, does the camera focus , or its keep on trying to focus. if the camera would not focus the image it wont take the picture.
3) even it focuses the image instantly and still it is taking long time to expose the photo. ???
Mar 14, 2008 | Fuji FinePix S5500 Digital Camera
Focus
This camera has TTl auto focus so it can't be switched to manual so that idea is quickly stomped on. A silly question, are you half pushing the shoot button down first to activate the auto focus. If you don't and just hit the shoot button you'll definitely get out of focus shots. Have you sat down and read the manual on how to correctly focus. A number of things can crop up which can fool the autofocus into a wrong setting. Have you dropped the camera or has someone else done so? The lens assembly could be damaged. Try pointing the camera at something about three feet away whilst half pushing the shoot button then still holding the button half way point the camera at something a long way off. Can you hear the mechanism trying to focus and does the picture in the LCD change. If it's all quiet and the picture doesn't change then it could be a damaged focus motor or a connection to it is broken. Are you sure the camera isn't switched to Macro. A lot of people get caught with that one. You'll never shoot a focussed picture in macro unless it's less than a foot or so away. BMW
May 31, 2006 | Samsung Digimax A400 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
22 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
