Question about Olympus VP-1 Multimedia Projector
My power light goes to red/amber constant, and my status light is flashing red. I hit power and it sounds like its powering up but then makes a wierd clicking noise and I get nothing?
  • Olympus Master
  • 11,800 Answers
The clicking noise it's the protection disengaging the main relay because the power source has detected a fault. You must open the projector and test the power source - start by looking for failed capacitors or burned resistors. If you don't know how they look or how to do that then it's time for a pro, don't mess with it or you're gonna make the failure worse.
Posted on Aug 24, 2010
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Light goes green but no display.
Definitely Power Supply Board. Check carefully for open 1/8 watt metal film resistors. They wont show signs of overheating but they can be open anyway. I've never been able to find a print either. Once you do find open resistors make sure you measure for shorted components in the associated circuit.
Jun 15, 2009 | Tatung P46ACTP 46 in. Plasma Television
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
My thomson dtr
just found this solution and it worked for me ............. though it wiped the hard drive ............ basically restores to factory settings
turn all power off and back on again press stand by button repeatedly until flashing amber light is n constant them quickly press up down left right in that order as quick as you can .............
good luck
Nov 11, 2008 | Televison & Video
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Olympus VP-1 Multimedia Projector Logo
49 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
