Question about Panasonic KXTGA641T Phone
Panasonic KX-TGA641 handset - the line cuts off as soon as I press the speaker button
  • Anonymous Mar 21, 2014
    resetting time will not hold, always go back to previous time
After following the instructions in the operating instructions manual multiple times, I called Panasonic at 800-211-7262. I spent at least 10 minutes with support and what it came down to was unplugging the original base unit and taking the batteries out of the new handset. Then we followed the same directions and it finally worked. Should have known to unplug to reset, seems to be the case on every piece of equipment these days. Good luck!
Posted on Sep 14, 2010
How can i put my phones KX TGA641C in French?
PDF]Operating Instructions - Panasonic Canada
https://panasonic.ca/PCS/.../KXTG6411-12-13-14-OI-Eng.pdf
Panasonicappropriate service offered by your service provider/telephone company. .... Feature.KX-TGA641C. KX-TGA740C. KX-TGA840C. Handset. Display colour/ size ..... "Fran?ais" as the display language. .... This feature allows you to put an outside.
[PDF]Installation Manual - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tga641_im.pdf
PanasonicNov 19, 2008 - Charge the batteries for about 7 hours before initial use. Additional Digital Cordless Handset. Model No. KX-TGA641. Installation Manual.Missing: french
Dec 17, 2015 | Lands Phones
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
Panasonic kx tga641
The KX-TGA641 is the handset, and does not include an answering machine. If you have an answering machine connected to your phone line, what make and model?
Sep 06, 2013 | Lands Phones
How do I reset recording with my own message
The KX-TGA641 is the handset. You need to refer to the documentation for whatever answering machine you have connected to your phone line. Failing that, repost your question identifying the answering machine.
Feb 18, 2013 | Panasonic KX TGA641 Cordless Phone
How to reset my recording on the answering machine KX TGA641
The KX-TGA641 is the handset. You need to refer to the documentation for whatever answering machine you have connected to your phone line. Failing that, please repost your question identifying the answering machine.
Record new message
Assuming your KX-TGA641 handset is mated to either a KX-TG6431 or a KX-TG6441 base, follow the instructions on page 32 of the manual.
Apr 30, 2012 | Panasonic Lands Phones
How do i stop the panasonic KX-TGA641 from rolling calls to my cell phone
You apparently have call-forwarding activated. The exact procedure for deactivating it may vary by company, but in most cases you simply dial *73 on your phone (the Panasonic, not your cell). Contact your telephone company (the landline) for exact instructions.
Apr 24, 2012 | Panasonic KX-TGA641T DECT 6.0 ADDITIONAL...
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Hi..Caller ID function not working on our base and handset phones Model No. KX-TGA641. Used to, but now does not. Pls help! Thank u
I have a problem on a Panasonic two line handset phone that when one line is plugged into a VoIP line, it makes the caller ID not work for the other line. After going back and forth with Verizon, we finally figured this out. I haven't figured a workaround. And in my old house I used to have a VoIP line and a FiOS line and it worked. So either something has changed or the difference between FiOS and regular copper line from Verizon is making the difference. peter@phipower.com
Dec 30, 2010 | Panasonic Lands Phones
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KXTGA641T Phone Logo
864 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
