Question about Dell Inspiron 2650 Notebook
No power or lights on my inspiron 2650 laptop
Got 2 new cords still no lights or power. Tried taking out battery and just used cord, but still nothing. Also tried taking bat off and power cord, pushing power on and off to get rid of any extra power in laptop. still nothing
no sign of life. last power cord was chewed threw by cat hope that didnt kill mother board or cpu.
    Scholar:
  • 144 Answers
First you need to test your adapter first not the power cord.Check that your adapter can give out according to the adapter spec..maybe 16-19ou V.If it does and still you laptop don't turn on then you have motherboard problem.
takecare.
Posted on May 05, 2008
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 22, 2012 | Dell Inspiron 1525 Notebook
Dell inspiron Mini 1018 wont turn on, power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 11, 2012 | Dell Inspiron Mini 1018 Netbook
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
New battery - installed - will not charge
Hello. Try a different cord. If you do not have access to one, take your notebook and new battery and present power cord into any Staples store or other computer repair and have the cord tested. Joe
4 thumbs up please. ty.
Oct 20, 2010 | Dell Inspiron 2650 Notebook
Power cord missing need to make a new one
you can get a new power adapter and power cord from ebay.com
if you go there search for
"Dell inspiron 2650 power adapter" there is several oem power adapters for this notebook.
If you need the actual power adapter inside the notebook (the one on the motherboard) they sell them as well but they are rather hard to replace.
Thanks
Steven
Apr 29, 2010 | Dell Inspiron 2650 Notebook
It just all of a sudden lost charge and won't charge at all now..please tell me it's something instead of i need a new battery
If the notebook still powers on with the cord, then yes, it is your battery and you do need a new one. Sorry.
On the plus side, if this is the case, you don't need to send your laptop away for repair, or worse, buy a new one.
Jul 29, 2009 | Dell Inspiron 2650 Notebook
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 8500 no lights, no fan, nothing.
First remove the battery and try it. If it works without the battery, then that is the problem. My Inspiron 2650 suddenly started acting like that with the battery in but works perfectly without the battery.
Whenever you replace a battery ALWAYS let it completely charge BEFORE you try to use the computer with the battery in place.
Do the POWER, DISK ACTIVITY and/or BATTERY CHARGING light stay on?
If so try powering the computer off; unplug the power cord; remove the battery; carefully remove the RAM modules; check the connections for corrosion/dirt; them reinsert the modules; close up the case; plug the power cord in and try powering it up without the battery inserted to further eliminate the battery as the problem.
If you get NO lights or fan noise without the battery installed, you probably have a mother board problem, most likely in the power switch. With the 2650s the switch is an integral part of the motherboard (DELL calls them system boards I believe) and DELL recommends replacing the board. I guess if you can find someone brave enough to work on the board, you could fix the switch because DELL refurbishes them and if the board isn’t working anyway, then you have nothing to loose.
I hope this helps you. Good luck. The 8500s are good computers if you get enough memory in them.
Don Jones
Jan 25, 2009 | Dell Inspiron 8500 Notebook
Inspiron 2650 Laptop keyboard is locked.
If the keyboard is locked ALL the time, try unpluging the power supply, remove the battery, then push and hold the power button and any key on the keyboard for at least 30 seconds. then reinstall the battery, plug the pwoer cord back in and reboot it.
I had the same problem and that is what the DELL techs had me do. I had the problemm frequently for a while and then it just quit recurring. I haven't had the problem for a long time now.
I hope this helps.
Don Jones
Dec 17, 2008 | Dell Inspiron 2650 Notebook
Power supply issues or notebook problem?
It's a pretty common problem (Power pin failure). The pins/sockets are poorly designed and poorly constructed. The day-in and day-out jerking and pulling on the cable causes the failure.
This video talks about using a cable retention device to stop the problem. I have tried the product and it works really well.
Dec 26, 2007 | Dell Latitude D600 Notebook
Dell Inspiron 2650 Notebook Logo
196 people viewed this question
Alun Cox
