Question about GE GSH22JFR Side by Side Refrigerator
I have a GE TFX24R side by side Refrigerator, the refrigerator door can not close completely, it seems something is missing and I have to lift it to close the door. Can you tell what is missing and how I can get it fixed?
5 Suggested Answers
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
  • 73 Answers
SOURCE: Owners Manual for GE Model# TFX24R
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670882.PDF
Here is the info you requested.
hope i helped
please rate me
George
Posted on Apr 30, 2009
  • 4793 Answers
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Posted on Mar 06, 2010
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
caroldon
  • 17130 Answers
SOURCE: Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Posted on Jul 31, 2010
My Ge refrigerator freezer door won't close
Have you checked for ice on the edge? also check the seal. they can warp and cause problems. Last try, is the door warped, like, did someone close it on something?
Mar 09, 2015 | GE GSH25JFR Side by Side Refrigerator
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Jul 31, 2010 | GE Refrigerators
When we close the refrigerator door (side-by-side unit) the freezer door pops open slightly. The unit is about 14 months old and the seals look fine.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Eric
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Broken door hinge
Its not hard at all,Just losen all the bolts an the door would well, fall of :)
Just check if the fridge dit not get hurt or the door,other wize go for it....
Good luck.
Sep 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
GE GSH22JFR Side by Side Refrigerator Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
