Repair manual for reddy heater 150,000 BTU model R150A serial 1191425 kerosene bullet heater
  • 674 Answers
SOURCE: I have a 115,000 btu
Get online to www.desatech.com You and download a manual there.
There are two ports on the black box behind the fan motor. One is just a plug where you should connect a pressure guage. The other is like a relief valve that keeps the pressure in the black box constant. The air goes to the fitting behind the fuel nozzle. This fitting is an eductor. The air flowing through it creates a low pressure which then draws the fuel to the nozzle. The air pressure and therefore the amount of airflow controls how much full will be drawn in. More pressure, more fuel. Less pressure, less full. To lower the pressure, back the screw out that has the hole in the center.
Posted on Dec 20, 2010
jyackle5
  • 8197 Answers
SOURCE: I'm looking for a manual
You can get the manual on the link below.
http://www.managemylife.com/mmh/owner_manuals/16378/KENMORE-Space-Heaters-Wall-Unit-L0812162?brand_name_search=356820
Good Luck
Posted on Dec 23, 2010
heatman101
  • 43501 Answers
SOURCE: I have an AllPro 150000
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 04, 2011
  • 674 Answers
SOURCE: My Reddy Heater 50,000 btu
Take the top of the heater off. It should be about 6-8 screws holding it on. Be careful around the fan and plug the heater in. Check for the igniter sparking if it is the spark plug type or glowing if it is the HSI(hot surface igniter) type. If it isn't, check the gap on the spark plug and you will have to check the transformer for it also. If it is a HSI, make sure it is broken. This type is very brittle and easily broken. Next use a flashlight to look for fuel spraying from the nozzle. If it isn't, the fuel nozzle may be clogged. You can use a very small piece of wire to push through the nozzle to clear it. Also check the fuel filter. You can check for water in the fuel tank too. If it's really cold it could be frozen blocking the fuel flow. If you still don't have fuel flow, check the air filters. There are 2 on the back of the fan motor. You will have to remove the black cover to see one of them. Let me know what you find if you don't get it fixed.
Posted on Jan 09, 2011
heatman101
  • 43501 Answers
SOURCE: my 60,000 btu reddy heater
heatman101
Posted on Feb 11, 2011
Testimonial: "God Bless you!"
Model# WP071107R, Serial# 10/2007, Reddy Heater 150,000 BTU The fuel tank has a crack. Where can I get a new tank?
You can try reddyheater .com or try a two part epoxy. Clean well with acetone, sand paper to create good adhesion then JB Weld or any other good grade epoxy. This will work in a bind until you locate a new tank.
Dec 20, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Hi, I have a Gilson 150,000 btu Torpedo heater
go to the DESA site they have nozzles for just about any torpedo heater.
Oct 16, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Need to download a reddy 170,000 btu heater manual any idea what site to go to
Go to DESA International website and download
manual. You will need model number of your unit.
Dec 30, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
816 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
