Question about HP LaserJet 4700 Printer
Replaced yellow toner cartridge - 4700 doesn't recognize that it has been replaced. Tried a 2nd cartridge, same result. Tried a reboot, also. Is there a reset menu where I can tell it a new cartridge was installed?
EPIJAB
  • 89 Answers
SOURCE: Refill Toner Cartridge for Laser Printer
I work for a company that does this and can tell you it is possible. Some companies do the drill and refill and some like mine actually take the cartridge apart and replace the drum and wiper blade.
You can buy the kits to refill your own. Usually, it just involves drilling a hole and pouring in the toner. This is the first I have heard of the melt and pour. Just be aware that eventually the parts inside will wear out and start to show image defects. You don't recommend reusing them more than twice.
Posted on Feb 15, 2008
  • 59 Answers
SOURCE: Out of toner........ but not really.....
You can also navigate through the menu and go into toner override mode. That allows you to print without being bothered by low/empty toner messages
Posted on Mar 11, 2008
SOURCE: HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Posted on Nov 01, 2008
  • 2692 Answers
SOURCE: HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Posted on Jan 24, 2009
POCBM
  • 121 Answers
SOURCE: laserjet 4700 only prints magenta
Ok, The fact that the cyan was working and stopped after you adjusted the frame and the magenta started leads me to think the HV was OK to begin with the cartridges were just not making contact. When you adjusted the frame you were likely moved the magenta into position but the cyan out of position.
I would go back to the side you adjusted to correct the problem.
see if the toner in the slots that don't work have excess movement side to side.
See if you can shim them over with folded paper so they would push against the HV contacts. If this works you would have to adjust that frame again make sure it is straight and will hold all the cartridges against the contacts.
The fact that the frame was bent to begin with scares me a little.
perhaps the machine was dropped.
You will also want to check the lase scanner assemblies make sure they are all installed properly.
Hope this helps
Posted on Mar 27, 2009
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
Konica minolta 4690mf doesn't recognize yellow toner cartridge
ARE YOU USING GENERIC TONERS? IF YOU ARE THAN YOUR GONNA HAVE TO USE ALL GENERIC NO MIXED TONERS.
Mar 26, 2013 | Konica Minolta Magicolor 4690MF...
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Lexmark pro 705 wont recognize cyan ink
Make sure that you're using genuine Lexmark cartridges. If you are, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Reseat the printead again and the cartridges then reboot the printer. If it doesn't help, try replacing the cartridge.
Apr 25, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Brother MFC 9440 won't recognize new toner cartridge
I knew it needed to be reset to recognize the new toner. Glad you found the info in the electronic menu. Thanks for using Fixya. If my suggestion was helpful could you please rate it for Fixya. Thanks
Dec 05, 2011 | Brother MFC9440cn AllInOne Laser Printer
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
Brothers MFC885cw can't recognize new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Brother Multi-Function Center MFC-240C...
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4700 Printer Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
