Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Red light indicates high temp in freezer .Freezer not freezing what do i need to do ?
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
