Question about Toshiba TLP-ET1 Multimedia Projector
Unit turning off after displaying red pc chip icon
This unit had previously been working fine and is very new.
Now when it is turned on the Toshiba start up screen displays for a few seconds, then a red pc chip icon displays in the top left hand corner. The unit then shuts down the lamp and after a minute turns off completely. Before this LED lights on the unit show 'On' red lit, 'Lamp' orange lit, 'Fan' green lit. The manual does not reference this sequence.
  • 563 Answers
Hi whitiezn
If you say that this unit is very new , it should on all accounts still be under warranty.
Contact your local Toshiba Service Centre and have this problem sorted out on their account - the machine should still be under warranty.
Posted on May 06, 2008
I went to move my Toshiba p205 notebook from the desk to my bed and the screen turns white I've tried restarting it and window Vista makes the start-up sound but nothing comes up on the screen except a...
HI:
Try taking out the battery and leaving the unit unpluged and free of power for at least ten minutes. Then try restarting the unit normally, if the screen is still white then this means it is not receiving data from the graphics processor, if so then this is a indication of a faulty video processor or graphics chip, you may of gathered static electricty while walking across carpet that may of shorted the chip. In which case the only thing that can be done is to either replace the mother board in the unit or send it to toshiba for repair and replacement of the main board, you may want to contact Toshiba first before going futher as they may have a solution for you.
Dec 19, 2010 | Toshiba Computers>Laptops Satellite A10 PC...
Toshiba satellite 2060 CDTW will not turn on, will not boot. Lights: plugged-in on, battery on, others off. When power switch is pressed, HDD light turns on and remains on with apparently no other...
Thats sounds like a ram problem. If it was cpu you should still get a beep or post code. If it can't read the first 64kb of ram in the first chip it will do this.
I would take the ram out and swap the sticks. Then try to boot. If you get it then the chip is the problem. Older ram sockets can loosen up with heat cycle, vibration etc so it could be something as simple as needing to reseat the ram stick and it will work.
The next thing to check would be the cpu. It might be the chip or the socket again.
The power light is strange but I've seen it when the cpu is out when the power transitors go on the board. It may be a fault caused from the cpu.
I still have a 486 Tosh I use. Still can't type faster (or speull bettter) now then when it was new so it still does some things just fine ;-]
Aug 20, 2010 | Computers & Internet
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
C470
this is a fuser unit error code. reset code in following way.
1, turn off power. 2, hold down 0 & 8 keys. 3, turn on power still holding keys down until beep is heard. 4, enter 400 on numeric keypad. 5,press start button. 6,enter 0 on numeric keypad. 7,press enter icon on the main lcd display.8,cycle power
Oct 05, 2009 | Toshiba e-Studio 350 Copier
Toshiba tecra 9100. No standby or hibernate functions
This means that your laptop does not have the display drivers installed. Check you check in the control panel, go to system icon and click on device manager? Check to see what VGA drivers are installed.
Do you see an esclamation mark?
Mar 14, 2009 | Toshiba Tecra 9100 Notebook
Have toshiba satellite A60-S1591ST Put new battery in after unit
Try hitting F8 when booting, booting to Safe Mode, and running System Restore to revert back to a time before your issue began. Post back with how it goes.
Dec 29, 2008 | Toshiba Satellite A60-S1591ST Notebook
V-chip setting
Try this:
Turn Unit ON.
Set the DVD Mode.
Press and hold the 'STOP' key on the front panel.
Simultaneously press and hold the '7' key on the remote control unit.
Hold both keys for more than 3 seconds.
The On Screen Display message 'PASSWORD CLEAR' will appear.
The 4 digit password has now been cleared.
Bill
Nov 01, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Power OFF button doesn't work; unit keeps running, overflows, and doesn't stop
I have the same problem! The "pcb" referred to in the previous reply is undoubtedly what Sears refers to as the "COVER ASSEMBLY, DISPLAY", part number 3551A20109B. It is possible, but highly unlikely, that the defective part is the ESCUTCHEON, p/n 3831A20079D. Sears lists the cost of the COVER ASSEMBLY, DISPLAY as $17.25 plus, undoubtedly shipping and tax. The part seems to be available only from the Sear Web Site under "PArts Direct". This dehumidifier is a piece of garbage. I previously had to replace the SENSOR ASSEMBLY, p/n 6877A30013L. This item turns off the unit when the water tank is full. This dehumidifier has my room flooded - twice - when the unit failed to turn off and overflowed.
While under waranty Sears/Kenmore attempted to repair the unit five times. They never succeeded and when the warranty ran out they would not repair the unit unless I paid for it. Thats when I started doing my own repairs!
Oct 01, 2008 | Kenmore 54701 Dehumidifier
Toshiba D-VR4XSU "system error" please wait. flashing "ok" in box below
oh my gosh that worked perfectly!! thanks so much
ive had t his problem 4weeks!!!
Mar 25, 2007 | Toshiba DR4 DVD Recorder
Toshiba TLP-ET1 Multimedia Projector Logo
102 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
