Question about Kenmore Dryers
The dryer timer does not progress in any setting and there is no heat. Kenmore model # 110.76677610 One site said that the timer is no longer manufactured. True?
  • 36 Answers
I would think you could still get it id check around. Im sure you could at least find a used one some were.
Posted on Aug 24, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2013 | Kenmore Dryers
After dryer shuts off, timer continues to run. Kenmore model #110.86181810, part # I think is 692032 and sears says it is no longer in stock. Anyone still have one?
I assume you're talking about the buzzer. Many high end dryers do that until you remove the clothes. heated clothes can set wrinkles if kept in the same position for a long time. it's a feature, not a problem, unless it keeps buzzing after you remove the dried clothes!
Apr 15, 2013 | Kenmore Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
20 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
