Question about Pasquini Livia 90 Espresso Machine
My husband removed the steam wand from our Pasquini Livia because I am running out of steam too soon and I thought the wand needed to be tightened. Now we need to know exactly how the springs go back when reattaching the wand. Thank you.
  • 1,089 Answers
There should be a brass disk also. The spring goes in first, then the brass disk with the curved side down, then the wand, and then the nut.
Low steam pressure, could be a sign of scale build up, or the heater is getting covered with sediment. The heating element is on the bottom of the boiler on a Pasquini. Also check you pressure gauge. It should b shutting off at 1.1bar of pressure. If it is lower that could be another cause of low pressure. It can be turned up by the pressurestat.
Posted on Aug 24, 2010
I have an older Pasquini Livia purchased in the early 90s. It continues to heat up and then the relief valve goes off. Is there a thermostat to replace?
Yes, remove the top panel on the right side is a p. stat with a microswitch on top, either that has to be replaced or the tube is blocked and it cannot read the steam pressure.
Nov 10, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Descaling the livia 90
The proper and only way to descale the boiler should only be done by a trained technician. As far removing the water tank goes, you simply lift it up from the left and right hand sides - this may be difficult if you have never removed it since calcium may have built up on the seal at the bottom of the reservoir - simply wiggle it side to side to remove. To clean the reservoir, you can use a green scour pad with water. If it is heavy build up you can use a product called CLR, and let sit overnight. You can save the CLR and reuse. Rinse well to remove all clr.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Abernook Pasquini Livia 90 Automatic
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
Oct 18, 2008 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
145 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
De Brewerz
De Brewerz
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
