Question about Grohe Shower Freehander 27 007 Chrome Shower system
How do you make the shower move easier - Grohe Shower Freehander 27 007 Chrome Shower system
Where do i find parts
Probably you should find parts for your Shover ar the nearest hardware store or home depot. Take some good photos of your shower, visit home depot and find some empoye ready to help you (not easy)
If you could specify the make of your showe, might be easier.
Oct 12, 2015 | Home
Stripped screw hosebib outside spigot
its probably cheaper and easier just to change the bib....but if you have a easy out you can drill and remove the screw that way and then go to hardware and get another screw and get parts...
Jul 15, 2012 | Dmm Free Standing ADA Compliant Valve ...
Can't remove valve on moen TL2377 shower faucet. I removed the handle by removing the screw. There is a chrome cup that I believe is a decorative cover over the valve stem. That is stuck and I don't want...
Take the round cover plate off and it will make getting that part off easier. You will be able to use a screw driver to help in removing it.
Be gentle and good luck
Apr 05, 2011 | Moen TL2377 Chrome Castleby Single Handle...
We have a pressure balance tub and shower faucet (D510055BN) that has become stiff and jerky to open. How can I loosen it to make it easier to open and turn on the shower or tub?
you have to turn off water ....remove cartridge and use heat proof plumbers grease on all inner and outer parts of value and cartridge and body...do not be shy with grease...this should make it better than new...if not buy a new cartridge then grease all...try first to see if works..
Feb 22, 2011 | Danze Sheridan Tub & Shower Faucet
How to adjust temp control for sigle lever shower control
Temp control is only accomplished by moving handle to desired position. If your asking is the hardware that in behind the single lever going to allow for adjustments, then the answer is NO. I installed the same into one of my bathrooms several years ago and I know what I am talking about. The single handle on that type on mine starts off then cold to hot. Problem is I wait for hot water to max so I can adjust it down to a comfortable temperture to prevent being burned. I refuse to buy one for other tubs. The 2 handles make temperture much easier with less wasted water used until its hot. Remember if you decide to replace with a two lever model then you will have to replumb the pipes for a two handle hardware unit (thats the stuff behind wall that your single handle goes into to which is currently plumbed for a single handle hardware unit.)
Oct 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
How do i disassemble this shower head to clean out the mineral deposit?
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Jul 12, 2010 | Grohe 27.069.EN0 Relexa Ultra Shower Head...
Replace the cartridge for a moen shower
It is stuck, they come out very hard and a puller is made to make removal easier.
Nov 12, 2009 | Moen & Replacement Cartridge
The shower turns on while I'm running the faucet without the valve being opened
The diverter needs to be replaced. It will probably be easier to just replace the whole tubspout.
Look for a allen wrench set screw on the bottom of the spout. If your's is not an allen screw mount, thenm remove the spout by turning counter clockwise.
Oct 03, 2009 | Moen & One Handle Tub & Shower Faucet
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Mar 04, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Grohe Shower Freehander 27 007 Chrome Shower system Logo
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
