Question about Amana ASD2326HEQ
The coil is not very accessible for cleaning. How do I get that done? Do I have to disassemble any part of it? Amana Side by Side, Model# 5xd2552e.
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Amana fridge side x side SKD22S2L. The Door frames are really "Hot" mainly the center frame on the side by side. I cleaned the evaporator coils and seamed to help a little but still getting hot.
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Feb 07, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Water collecting under produce bin which has to be collected every couple of days.Amana model # TX21VE 7.74 amps
Your drain is clogged. Every time it defrosts the water from the defrost should drain out to a catch basin under the ice box. That drain is clogged. You need to access the drain and clear it.
AMANA BOTTOM MOUNT SERVICE MANUAL
2 megs printable version
Helpful?
Sep 30, 2010 | Amana Refrigerators
heatman101
Aug 24, 2010 | Amana Refrigerators
Clean coil light comes on - requre detail
Remove the front grille, vaccum the coil or brush with coil brush.
Jul 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Clean coil light is on
The coil they are referring to is the condenser coil, which will be located underneath, and can be accessed either by removing the toe plate in front, or by pulling the cabinet from the wall, removing the machine compartment cover by removing the screws. In both cases its best to use an appliance brush or lint brush available at any hardware store, these brushes are about 2' in length, and contain black plastic bristles, and of course, unplug your refrigerator before doing any maintenance. Remove the dust and pet hair from the condenser with the brush, then vacuum the brush clean and repeat.
Jun 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How do I get access to the coils on an Amana model SXD22S2W,
on most refrigerators the plastic grill is a snap on most service tecks carry a long
brush that looks like a cats tail to clean the condenser coils a long bottle brush will also work but be gentle the tubing is metal the fan is normally located looking from the front back left corner if you have a plastic putty knife you can insert on top behind plastic close to the side and easily pop forward very few units are secured with screws ron
Dec 05, 2009 | Refrigerators
Freezer & refrigerator are not cooling enough.
there is a couple of things you can try. you can try to defrost the whole unit. it is not always a good idea to turn it up to the max setting. if the inner coils get frozen up it causes the problem you are having.
Sep 23, 2009 | Amana ASD2625KE Side by Side Refrigerator
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ASD2326HEQ Logo
20 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
