Question about Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
When I turn the Karcher on it runs, butonly at low pressure. Doesn't matter whether the wand control is Max orMin.
I have water supply of about 33 gal/min (15 litres/min) (i.e.sufficient to operate 520M).
I dismantled the pump mechanism and cleaned everything.When I opened it I suspected the "spill valve" was jammed, but itsnow AOK.
Anyone with any experience please? I can't quite work out what switches on the high pressure side of the thing.
Exploded spare parts list at:
ANY pointers very gratefully received.
  • 2 more comments
  • pdewick1 Nov 02, 2008
    Powered up the washer, the motor started, cut off, then nothing. All i get is water delivered from the supply atlowpresure, no high presure water.
  • vwq47 Nov 05, 2008
    GREAT and helpful explanation. Thanks MG - though where I live these valves are not cheap at all!
  • Anonymous Mar 18, 2014
    water quirting out of middle white value & pump cuts out
  • Darren Keating
    Darren Keating Jun 06, 2014
  • 92 Answers
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
MG. (Karcher service engineer).
Posted on Nov 04, 2008
  • Darren Keating
    Should I change my machine for a new one?
  • Darren Keating
Karcher k5.700 wont run continuously at high pressure
Your unloader or your packing could be cooked and these washers can be a pain to work on or to even find someone to work on them. Since it is a cheaper fix I would replace the adjustable nozzle on your wand first. Those are notorious for going bad. Then you have no pressure and you think your pump is bad. Most electric washers arent worth working on as the cost of parts and labor often exceed the cost of buying a new one. look on your manual for the unloader and packing or jsut go here. FIND PARTS FAST Good luck!
Feb 20, 2015 | Karcher Garden
I have a 520m karcher high pressure cleaner when turning it on it trips the electricty therefore I cannot start
try turning the motor by hand somehow to c if u can free it then try again or possible bad capacitor??
Jan 02, 2014 | Garden
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
May 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
3,699 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
