Question about Kitchen Ranges
Manual for State Select Hot Water Heater Model Model PR 650XCUIT-200
  • 177 Answers
SOURCE: installing hot water heater
Do you have a valve somewhere in line that is not open all the way or worse broken. Shutoff valves can stick closed.
Posted on May 13, 2008
  • 2692 Answers
SOURCE: Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Posted on Mar 16, 2009
heatman101
  • 43501 Answers
SOURCE: hot water for 3 min electric heater. drain water .
Your hot water heater has two elements. The top one is working, but the bottom one is not....
The problem is most likely the bottom element, but could also be the thermostat at the top element that is not switching the power down to the bottom.
Either of these problems will give you just a few minutes of hot water as only the very top of the tank ever heats up.
http://www.fixya.com/support/r3689051-home_water_heaters_hot_water_heater
heatman101
Posted on Mar 27, 2010
canwoodjc
  • 3301 Answers
SOURCE: We have a one year old home with PEX pipe and one
i would check the softener before the water heater, when was the last time you did a back flush of the system? water sitting at the bottom of a water softener tank can get moldy and begin to rot, which causes H2S gas which smells like sulfur , its a breakdown of decay,, this will also happen if your home is using well water,, so check that first , empty the tank and clean it our ,, then back flush the system
Posted on Jul 03, 2011
  • 5089 Answers
SOURCE: State Water heater pushed button to turn water down - all lights were lit initially.now no hot water - tried to reset - not resetting - help!
Which water heater do you have?
Is this gas or electric, tank or tankless?
What button did you push to turn water down??
Do you mean turn down water temperature?
What lights do you have that are lighting up?
Posted on Aug 11, 2012
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
When trying to ignite electric pilot light, when pushing button to ignite, pilot doesnt spark to create flame
Pull out sparking rod and lightly polish with fine steel wool. then put back together. Could be in control box but I doubt it. You will probably see mild corrosion on rod.
Apr 02, 2014 | State Water Heaters 50 Gallon Select SL...
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
