Question about Acer Aspire 5500 5570-2609 Laptop
I have acer aspire 5570, when i try to connect to wifi netowrks which are secured by WPA2-PSK, it fails, when i check the settings i got my wifi doesnot have any option in network authentication with the name WPA2-PSK.... i found WPA-PSK only... tell me what to do ??
  • 36 Answers
Are you putting in the right password they are locked unless you put in the right password.
Posted on Aug 24, 2010
I USE MIFI TP-LINK MODEM M5250..THE PROBLEM IS WHEN USE MY COMPUTER TO CONNECT TO MIFI WIFI SIGNAL ITS DOESNT HAVE ANY PROBLEM...BUT THE PROBLEM IS WHEN I TRIED TO CONNECT USING HANDSET THE WI-FI SIGNAL...
If you don't have access to the settings the handset is using to select the security protocol, or know what they are, the issue is probably with the protocol the handset is using to connect to the wifi, Check the computer that can connect, to see which protocol it's using. Then, I'd try a support ticket with the manufacturer of the handset to see if the issue is resolvable. It really depends on how flexible the handset protocols are...None, WEP, WPA2-PSK (TKIP), WPA2-PSK (AES), and WPA2-PSK (TKIP/AES) are all different options. Choose the wrong protocol, and you can't connect.
Jul 02, 2017 | TP-LINK Computers & Internet
We have a vizio smart tv but cannoy connect yo wifi.What should we do?
Vizio will not connect with Netgear wi fi, BUT if you want to try it, you have to adjust the security
If you have the skilset then..........
Set your router to use both WPA-PSK (TKIP) and WPA2-PSK (AES) and the TV finally connected using the WPA-PSK (TKIP) security!
Mar 06, 2014 | LG Televison & Video
WIFI
It appears to be asking for the WIFI password. wpa/wpa2 psk are encryption protocols. In order to connect you need the shared network password.
Jul 26, 2013 | Acer Aspire Computers & Internet
Installing blu-ray disc player w/ built in wifi. my router is set with WPS security. blu ray won't connect because cannot support theTKIP security type in 802.11n mode . How do I change the se
Try different security types. WEP, WPA2-PSK . Setup the device, you didn't post the Make, Model of device, to WPA2-PSK if you need to update the firmware go to the manufacturer's website and install the latest firmware version. If you need to update the firmware in the Samsung take a look here: http://www.samsung.com/us/support/owners/product/BD-E5400/ZA
Apr 06, 2013 | Computers & Internet
Aspire one 722 can't connect in wep key connection
you should change it from WEP to WPA2-PSK and turn off WPS that is more secure and would most likely fix this issue
Nov 09, 2012 | Acer Computers & Internet
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
How to set a security cod for wifi
This is a Quick and easy fix!
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
I have an Acer Aspire 5570 laptop. I can't seem to get the wireless to work all of a sudden. I tried the front switch, but it didn't solve the problem. How else can I get connected to the wireless? TIA
Most Acers use a form of IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
Nov 04, 2009 | Acer Aspire 5500 5570-2609 Laptop
Connecting to woreless internet connection
Be sure you use same security protocol on your PC than in your WLAN:
WEP or WPA or WPA2 protocol
Passphrase (PSK ) or Password
TKIP or AES.
Use same Key.Passphrase on your notebook as in your Access point.
Check if your Access point/router has access list enabled: either you disable it in your AP either you add your PC MAC address to the list.
Dec 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 5570 Wifi drivers on Windows XP and Ubuntu 8.xx
Windows XP is outdated none of driver is supporting now.
Sep 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
225 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
