I got an LG 500G monitor, I just solved my power problem, now my monitor is powered up, but now another problem comes up, after I plug in the power cord and turn on the monitor, it shows "no signal" on the screen as usual (I didn't connect it with my PC). but the H-deflection seems unstable, the picture is narrowed for 1 second and then back to normal for about 1 second, it just keep repeating like that until the monitor shutdown itself in about 7-10 second after I turned it on.
and if I connect it with my PC, the picture won't comes up and the power indicator color is amber (the manual book calls it DPM mode).
and another one problem is, I foolishly replace the EEPROM in my monitor which make my monitor OSD becoming strange. can my monitor back to normal? Thank you for your help.
Undo what you did & it should hopefuly work.
Next time don't be overconfident and do things that you are not sure of. It doesn't hurt to ask someone who knows. Here you are lucky to escape with this one. I've come across cases where people have ended up short-circuiting their gadgets beyond repair.
If you have the previlege of having a manual, refer it, read every word carefully and then go about doing things on your own.
Was this helpful?
Yes
No
Popular Solutions for Gateway FPD2275W LCD Monitor
gateway fpd 1730 lcd monitor stays on power saving mode when I turn on the computer I checked the...
(More)
gateway fpd 1730 lcd monitor stays on power saving mode when I turn on the computer I checked the wires and it is connected to the pc, and pc turns on.
My Gateway FPD2275W LCD monitor has suddenly failed. It looks like dark liquid has leaked inside the...
(More)
My Gateway FPD2275W LCD monitor has suddenly failed. It looks like dark liquid has leaked inside the left 3 in. and a series of horizontal black lines appeared at the same time. Evidently the LCD panel has failed. Is it possible to have the LCD pannel replaced withouut having to buy a new monitor? Thanks, ****
We had to restart our computer after an update and now the monitor will not come at all. The tower...
(More)
We had to restart our computer after an update and now the monitor will not come at all. The tower will come on but mot the monitor.
When the monitor wakes from sleep the screen is filled with green pixels. Turning the monitor off...
(More)
When the monitor wakes from sleep the screen is filled with green pixels. Turning the monitor off then on again fixes the problem. Why is this happening?
