Question about Minolta Office Equipment & Supplies
My machine Di470 having problem with panel display error code c143e, can you tell me what is the problem, how to reset this error code or any part faulty. thanks. benson voon.
  • fayazalichan
    fayazalichan Nov 20, 2012
    plz ianforminton di470 rrrrrightn dool L3 whats pirobilum
  • 40 Answers
This problem in DFsection you most check and clean it maybe there is small paper on the sensor check it
Posted on Sep 01, 2010
??? ??? ??? c3451
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Feb 03, 2016 | Office Equipment & Supplies
Konica-Minolta bizhub 215 giving c3451 error message?
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
After changing overflow container what's next is there an error I need to clear?
sir does the screen display M -2 code ? I assume you are talking about the WASTE Toner Container??? Then go service mode and clear the counter and reset to 240k . Under Consumables
Service mode = utility, meter count, stop00 stop01 consumable waste toner clear and reset to 240K
Dec 18, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
What if the machine is showing c3451, what should we do?
Hi Stephen,
This error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
Try resetting it by switching machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on
This will hopefully reset the error code. However, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Apr 25, 2014 | Konica Minolta Office Equipment & Supplies
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Firmware on to minolta di470
Step 1:
C-10XX Memory board failure.Enter in the service mode and reset the trouble.2_6_2013_6_19_30_pm.jpg2_6_2013_6_19_42_pm.jpg
Step 2:
If you can t reset you have remove the right upper cover and the memory board metal cover to located a memory board reset microswitch.2_6_2013_6_27_55_pm.jpg2_6_2013_6_28_08_pm.jpg
Feb 05, 2013 | Konica Minolta Office Equipment & Supplies
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
378 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
