Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I want to use the upholstry attachment and I can't get the water to spray out the hose
  • 3 more comments
  • jcreps Aug 24, 2010
    The model number on the back of the machine is F5906-900 if that makes any difference.
    I think it is working now. . .thank you
    I think it is working now, thank you
    Now the water just trickles out. . .it's not working like it should.
  • jcreps Aug 25, 2010
    It is NOT working now. . . .I give up. . .going to use another brand of machine!!!!!!
    Brigadier General:
  • 3,513 Answers
Hi
Before using tool It may be necessary to remove air from the system (“prime the pump”) so the clean solution will flow to the tool. Follow the bellow instruction…..
Attach tool to hose and turn the carpet cleaner ON. Then put the tool on a hard surface or
against your hand to block off the suction. Now wait a few seconds (can take up to
15 seconds). Then squeeze the trigger and begin cleaning.
More elaborately what you can do is..With the hose attached, place your hand over the suction opening at the pick-up end of the hose. Then pull the trigger. The pump is suction driven, and if there is air in the water line in the hose, that is known to allow the hose to prime in about 10 to 15 seconds.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 24, 2010
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaks when trying to use upholstry cleaner!
This is a common problem for these units, and is easily fixed.
Bad connection:
You may need to push harder on the coupling when attaching it to the machine
A leaky Valve
Manytimes the Valve you connect to can bust or crack where you cannot see it.
Remove the hood and inspect valve. (six screws on underside)
Leaky hose
The hoses that run to the Valve you connect to can come loose or crack.
Remove the hood and inspect hoses. (six screws on underside)
This machine may be leaking the whole time you use it, and you my just not be noticing.
If you are in a northern climate, freezing machines in garages or cars is the most common cause.
Jun 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Will not spray water
After the last use did you run a FULL tank of HOT water throught he machine to clear the lines and the pump? If not the soap has clogged one of the two. If it is the lines simply remove them (one at a time is less confusing) clear them and all is good. If it is the pump (white L shaped object back left corner of machine as you face it) you will have to go to a local vacuum repair shop and order the part.
Apr 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Oct 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Upholstry set up for ultimate g kirby.
Remove the entire cloth bag assembly and put the hose on the side where the bag came from. Remove the power nozzle and put the intake guard onto the front. (this is in your attachment set...the only one with little hooks that sit on the bar in front) You can change from the long handle to the short if you'd like also. You get the handles off by pushing the "seatbelt button" located at the rear bottom of the handle and pulling the handle straight up and out. Now, put your spray gun on the hose. Don't forget the little suds nozzle that goes on the end of the spray gun. I like to use a half and half solution of Kirby shampoo and water in the gun. It makes a nice dry foam that only wets the surface of the furniture. If you use more water, it takes longer to dry.
If you need a manual (book or DVD) for your Kirby, try this link....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped...
Marci
Mar 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Upholstry attachement
The hose end should have a duct on it that you insert in front of the dirty water tank. It must be down all of the way so it will seal. This is where your suction starts from. Acouple of other reasons could be the dirty water tank lid is not locked down all of the way around, the back end isn't locked. If there is a foam filter on the bottom of the dirty water lid, there mustbe a gap between the top and the filter.
Mar 07, 2008 | Hoover F5832-910 SteamVac Supreme Vacuum
Upholstry attachment
Check to make sure that the hose hasn't cracked, where it hooks up near the motor. If so, replace the hose.
Nov 11, 2007 | Hoover F5906-900 Upright Steam Vacuum
Water flow issue
The attachment hose is likely coaxial - meaning that it is a vacuum hose with the water supply line running through it. It is likely that the vacuum (outer) hosing is damaged. The attachment will still spray, but will not vacuum. if you lay the handle section all the way down and look inside the unit, you will probably find the problem.
Aug 23, 2007 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
700 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
