Question about Pioneer DV-383S DVD Player
I have a Pioneer DV-383-S DVD player. When I switch on the player the player goes to a Regional Settings Screen where it prompts me to select a region code from 1-6. (Player?s Region Settings) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. It does not proceed beyond that screen. I am unable to go to any menu. I have tried resetting the player by pressing the STOP button and then the STANDBY button to switch it on, changing from NTSC>PAL>AUTO by pressing the FORWARD button and the STANDBY button. Nothing is working. Anyone else using this player and facing a similar issue..
How manuvel setting region codes
Posted on Nov 22, 2011
I have a DVD player, I don't know the brand name. It doesn't say it on the DVD player. I think it's a dvd player dd 383. I need a code for the skandia universal remote control, please.
The closest model to what you describe is a Pioneer DV-383 or DVD-383 and the following remote codes may work for you:
BW-0392
6 in 1 Pre Programmed Remote Control DVD Pioneer codes:
0175 0185 0665
(source: http://www.antennawarehouse.com.au/remotemaster/tech%20support/Universal_Remote_Control_code_list.pdf)
To have a look at the universal code lists for other products, visit:
http://www.antennawarehouse.com.au/remotemaster/codes.php
(Skandia remote support site)
It is the closest I could get. Not sure if it will help at all. Give it a try.
Apr 24, 2011 | Televison & Video
Tip
Pioneer DVD-400V DVD Player Interlace Reset
Pioneer DVD-400V Interlace Reset
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  1. Switch everything off.
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V HDMI Reset
on Jun 06, 2010 | Televison & Video
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
Hi. I´ve just buy a used Pioneer dv 383 and it works OK with Cd´s, but when I try to play a DVD on it, it turns off. Can u help me?
There are 2 lasers in it. One for dvd and one for cd. The dvd lens is overheating and causing it to shut down. Better to get a refund and buy a new one. They are very cheap at WalMart.
Aug 10, 2010 | Pioneer DV-383S DVD Player
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
I hope that helps.
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
I live in germany and want to play dvd,s from Australia, Pioneer DV-360 from german store
Most DVD players I've seen are either multi-regional or one-region units. The DVD player you bought might be a one-region device. I'd check on that first. If it is, then you'll only be able to play DVD's made for that particular region. If it is multi-regional, look in the manual or go to Pioneer's website to possibly find the codes.
Jun 14, 2009 | Pioneer DV-360-S DVD Player
Progressive/interlaced image problem
In the Initial Settings Menu go to Component Out, ther you can switch it.
May 16, 2009 | Pioneer DV-300-K Player
Open Questions:
Pioneer DV-383S DVD Player Logo
224 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
