Question about Samsung U900 Soul Cellular Phone
The touch screen of my samsung s6250 doesn't work. I can´t make calles. How can I fix it?
4 Suggested Answers
SOURCE: Hello! I had my touch screen
i was having the same problem for three days contentiously . but thanks god i solved it .try to take off the back cover and , SIM cards and memory card .Now use the hair dryer for 7 ,10 minutes and the problem will solve ,if not so may be you will need to take off the four screws to fix the cables from inside . wish that i helped you
Posted on Jan 20, 2011
  • 184 Answers
SOURCE: Touch screen doesn't work on
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care in solving the problem....
Posted on Aug 04, 2011
ivan_gueorgi
  • 128 Answers
SOURCE: how to make touch screen work when it doesn't
change the touch screen in samsung sevice center
Posted on Nov 08, 2011
My ST500 samsung digital camra's touch screen is not working, but everything else does perfectly is there anything i can do to fix this? I don't understand why it doesn't work it has not been...
you have a bad camera. If your camera is still under warranty, I will repair it for 35.00. If it is out of warranty, then I will fix it for 165.00
call Continental Photo, 718-268-6440 Mon - Sat 10am - 6pm, ask for vic
Jul 31, 2011 | Cameras
Touch screen for definition only works when I turn on the ereader and after that when I touch the screen for definition it doesn't work. It turns the page instead.
Hi Darnellakell!
I´m not sure if you already tried to reset the reader, turn it off, and hit the reset button at the bottom of the reader then turn it on. Just make sure the reader is fully charge, your books will not be affected =)
You can check this forum and ask your questions too =)
http://digialreader.freeforums.org/prs600-f8.html
Jul 03, 2011 | Sony Reader Touch PRS-600
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
Ricoh jp 5000 errore code message ec 5-51
Its a MP5000 right??
You have Loose connection of pressure roller thermistor.
Try this:
Press the clear mode key (yellow key)
Use the keypad to enter "107"
Old down clear/stop for at least 3 secounds (red key)
Enter the service mode (on the touch screen press "copy mode")
Exit all the way to return to the copy window.
Turn the machine off/on.
If doesn´t work you have to call technical assistence.
Feb 12, 2011 | Ricoh Office Equipment & Supplies
My Samsung S8300 touch screen
Touch screen suddenly not working for my samsung s8300.
keypad working but i can't call.
Jun 23, 2010 | Samsung S8300 Ultra Touch platinium-red...
Samsung m8800 my touch screen doesn`t work ...it hangs or get stuck sometimes ..what is the reason and got some solution for that or ..it`s just the software that has been made to hang after finishing it`s...
It is a hardware problem, there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
May 15, 2010 | Samsung SGH-E840 Smartphone
How do i get my samsung touch screen fixed pixels smashed
Call Samsung at 1-888-987-HELP(4357). It will probably be an out of warranty repair and cost though.
Oct 16, 2009 | Samsung Instinct Cell Phone
The touch screen on mym phone wont work its jst not working all together it just stoped
hi friend,
  • Issue – Bottom half of iPhone touch screen does not work.
    Solution - Standard troubleshooting steps in order are power the iPhone off and on, Reset, Restore from backup, Restore as a new iPhone or not from backup and if no change after any or all, call Apple Care – (800) 694-7466 or make an appointment at an Apple Store to have this checked if there is one nearby.
  • Issue - iPhone “touch screen” dead.
    Solution - Connect your phone to iTunes and do a full restore, it will replace all information on your phone prior to your last syn. If it doesn’t help call Apple Care – (800) 694-7466.
  • Issue - The top half of my iPhone screen is not working at all
    Solution - If restore doesn’t work – you could schedule online an appointment with a genius at an Apple store
    http://www.apple.com/retail/
  • Issue – My screen cracked. How much would it cost to get it replaced?
    Solution - Terrible situation but Apple doesn’t warranty the glass. This would be a minimum of $250 to get fixed out of your pocket.
Hope one of the solution helps…
thank u for using fixya
please rate me..............
regards
sivaranjini
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung U900 Soul Cellular Phone Logo
161 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
